Exhaust Camshaft - tacho drive worm
  • Lofty B
  • Lofty B's Avatar Topic Author
19 Feb 2018 11:38
#779001
Evening all from the middle of the Irish Sea
Z500 engine strip down started today - engine out and top off to find tacho drive in less than perfect condition. With ex' cam likely to be as rare as hens teeth - what options are there? Is a electrical tacho an easy upgrade?
Advice appreciated
Many thanks
Re: Exhaust Camshaft - tacho drive worm
19 Feb 2018 13:43
#779008
Pic of damage?
Good Fortune! :)
  • loudhvx
  • loudhvx's Avatar
20 Feb 2018 08:57
#779060
Lofty B wrote: Evening all from the middle of the Irish Sea
Advice appreciated
Many thanks
Usually damage comes from installing the EX camshaft without removing the tach drive pinion. Make sure that it is out.
Incidentally, you might want to check out the valve train warning page in my signature.
I can't check z500 part numbers, but the z500 camshaft may be the same camshaft used in the early Kz550's. The cam timing is exactly the same, so the camshaft itself is probably the same.
But I would always prefer an electronic tach.
I
  • Lofty B
26 Feb 2018 11:16
#779401
Took my time but here it is....
  • Lofty B
26 Feb 2018 11:18
#779402
Thanks Loudhvx
Unsure of options for modifying to an electronic tacho
  • azman857
  • azman857's Avatar
26 Feb 2018 20:14 - 26 Feb 2018 20:16
#779444
Most likely the electronic tach would get it's signal pulses off the coil or pickup. Either way it would be easy-peasy to do. If your wanting to keep your stock tach, then yeah, you need a replacement exhaust cam.
Last edit: 26 Feb 2018 20:16 by azman857.
