1977 kz400 cafe project.... help?
  • Dark_customs
  • Dark_customs's Avatar Topic Author
13 Feb 2018 16:23
#778716
Hello, I a new to the fourm/ any fourm lol. What I do know is there is a lot of knowledgeable people on them so hopefully I can get some help. First I share a little info on my build, this bike was my first back in 04 and has had a rough life since. It was stored in my dads damp basement for 8 years. As you can see in the pics I have taken it back to life and have spent countless hours powder coating , cleaning or replacing absolutely everything.
Now the question I hope I can get some help with;
I had the top end apart and powder coated it, bit now that I have it back together it leaks. Followed all the steps in the manual to a t. The compression is great and runs super smooth with the new mikuni carbs. I can see bubbling around the head gasket. I never replaced the o rings that fit in the head gasket for the oil ports, can that be the issue? Sucks to have to haul it apart again lol but that’s it, any help much appreciated
Attachment not found
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 1977 kz400 cafe project.... help?
13 Feb 2018 17:32
#778727
Go to KZ400.com and start reading.
The oil leak is a design flaw of the early KZ400 engine.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • k1z947060
  • k1z947060's Avatar
27 Feb 2018 05:50
#779459
I had a similar issue with my 76 kz400. I rebuilt it and oil/gas was bubbling from head gasket. After some research, I replaced 6 of the 8 cylinder stud bolts, bought new style kawasaki gaskets and o rings, and I took the head to a machine shop for them to make sure its not warped. They refinished the surface for $35 overnight.
I have not yet put my bike back together but I'm expecting, and hope that this solves it. It was a kawasaki service bulletin mentioned on KZ400.com; if you do it you need to make sure you buy the new parts per the new product codes in the service bulletin.
1976 KZ400
  • k1z947060
27 Feb 2018 05:53
#779460
k1z947060 wrote: I had a similar issue with my 76 kz400. I rebuilt it and oil/gas was bubbling from head gasket. After some research, I replaced 6 of the 8 cylinder stud bolts, bought new style kawasaki gaskets and o rings, and I took the head to a machine shop for them to make sure its not warped. They refinished the surface for $35 overnight.
Here you go...
"Top end oil leaks. Kawasaki service bulletin"
kz400.com/KZ400D3lFrameset.html
1976 KZ400
The following user(s) said Thank You: Dark_customs
  • Dark_customs
27 Feb 2018 12:21
#779487
Well thank you very much , I will look into getting the proper orings and gaskets.. appreciate it!
  • gordone
  • gordone's Avatar
27 Feb 2018 13:24
#779490
Dark_customs wrote: Hello, I a new to the fourm/ any fourm lol. What I do know is there is a lot of knowledgeable people on them so hopefully I can get some help. First I share a little info on my build, this bike was my first back in 04 and has had a rough life since. It was stored in my dads damp basement for 8 years. As you can see in the pics I have taken it back to life and have spent countless hours powder coating , cleaning or replacing absolutely everything.
Nice Project you have :)
Project:
