81 kz650 tank on a 84 kz700
  • USAtraveler
  • USAtraveler's Avatar Topic Author
09 Feb 2018 10:09 - 09 Feb 2018 10:15
#778417
Will a 81-82 kz650 gas tank fit on a 84 kz700??
Last edit: 09 Feb 2018 10:15 by USAtraveler.
  • martin_csr
  • martin_csr's Avatar
Re: 81 kz650 tank on a 84 kz700
09 Feb 2018 11:08 - 10 Feb 2018 06:04
#778422
Direct bolt-on >>> no.
The csr tank has a rear mounting tab that points straight down, so it's 90o off from the KZ700.
Do you have a 700 tank to measure? for comparison to a csr tank. in case it can be adjusted to fit.
I'm pretty sure the 82 GPz 750-R1 & 83 750-L3 tanks will fit the KZ700.
Also, probably the L1-L4 models sold in the UK & maybe the GT750s sold in the UK.
Last edit: 10 Feb 2018 06:04 by martin_csr.
