bore
- Customkz1366
bore
06 Feb 2018 18:52 - 06 Feb 2018 18:54
if i have a 50 over bore on my kz 1000 whats my cc?
Last edit: 06 Feb 2018 18:54 by Customkz1366.
- Zeerx
Re: bore
06 Feb 2018 19:22
I just had my 1000 (1015) bored 1.0 over. It's now a 1045. So your is probably a 1030 now. If I remember correctly.
‘78 KZ750B, ‘12 F150 (Ford)
The following user(s) said Thank You: Customkz1366
- Nebr_Rex
Re: bore
06 Feb 2018 19:30
.050 of an inch or .5 mm?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Customkz1366
Re: bore
06 Feb 2018 20:44
when i took my bike apart there was a 50 stamped on top of the piston
- azman857
Re: bore
06 Feb 2018 22:39
.5mm
- zed1015
Re: bore
06 Feb 2018 23:14 - 06 Feb 2018 23:15
0.5mm OS will be 1030cc.
Every 0.5mm OS is worth approx 15cc or each 1mm OS is approx 30ccc split across all 4 cyls.
Most popular piston kits go up in oversizes of 1mm increments so usually stock 1015cc then 1045,1075,1105 etc.
Last edit: 06 Feb 2018 23:15 by zed1015.
