Transmission/Gear Noise - 1981 KZ750 LTD
- Irish Yobbo
04 Feb 2018 22:07 - 04 Feb 2018 22:09
I've had this bike for about a year now, but it's always made this noise when in gear and under load (doesn't need to be much, but if the engine is pushing the bike, it makes this sound). It seems to come from the gearbox or lower part of the engine, and is more pronounced on the left side of the engine.
There's also a bit of a 'whir-whir-whir' sound which can be heard at highway speeds - might be realated. The whirring sounds like a bearing issue, but I don't know about this one. Any ideas?
1981 KZ750 LTD
Last edit: 04 Feb 2018 22:09 by Irish Yobbo.
- janroger64
Re: Transmission/Gear Noise - 1981 KZ750 LTD
11 Sep 2024 13:19
Hello!
Did you find out about this noise?
I have a 1981 KZ1100 shaft with a wining noise coming from the transmission area.
janroger64
janroger64
