oil pressure switch
  • gregoryzim
  • gregoryzim's Avatar Topic Author
oil pressure switch
03 Feb 2018 23:53
#778172
HI - I have a simple question re my 82 KZ1100 please - can the oil pressure switch be connected to a pressure guage (digital) so the actual pressure is always displayed? If so - is it a direct connection or does is have to be wired via something else on the loom?
Thanks.
Greg
  • zed1015
  • zed1015's Avatar
Re: oil pressure switch
04 Feb 2018 02:43 - 04 Feb 2018 02:55
#778176
The pressure switch on these engines is mechanical and is basically an on/off, pressure/no pressure indicator.
You need a mechanical gauge with a M14 x 1.5mm adaptor to screw in to the main oil gallery.
There is a threaded bung top left of the ignition housing which is for this purpose.
Last edit: 04 Feb 2018 02:55 by zed1015.
  • gregoryzim
06 Feb 2018 00:01
#778309
OK tks. Is the M14 x 1.5 the same as 1/8 NPT - because thats what the manual says that testing point thread is?
Tks
Greg
  • zed1015
  • zed1015's Avatar
06 Feb 2018 03:31 - 06 Feb 2018 03:33
#778316
1/8 NPT is the usual thread on the back of an oil gauge but is nowhere near the M14 ( 14mm ) of the pressure port.
The Kawasaki uses only Metric threads so you would need a 1/8 npt to M14 adaptor.
The official Kawasaki oil pressure gauge screws in to the port next to the ign housing.
The pic shows the location of the port with an aftermarket gauge attached.
Last edit: 06 Feb 2018 03:33 by zed1015.
