overhaul engine top
  • gordone
  • gordone's Avatar Topic Author
Re: overhaul engine top
06 Feb 2018 01:15
#778313
gregoryzim wrote: A picture says a 1000 words. Can you post a picture of these shims in place please? Doing the top en don my KZ1100 is the winter project for me as I need to put new stud O rings in so will need to check everything else when doing that.
Tks
Please see attached photo. The smallest shims I have is 2,4 and have now order 2,0 I can use to find correct shims.
You think I will not get any space with 2,0 either?
Project:
  • Nessism
  • Nessism's Avatar
06 Feb 2018 04:59
#778318
If you are already at 2.4 and no clearance I'd remove the valves and have your machinist shave the stem down a little.
  • gordone
06 Feb 2018 05:08 - 06 Feb 2018 06:29
#778320
Nessism wrote: If you are already at 2.4 and no clearance I'd remove the valves and have your machinist shave the stem down a little.
Thank you,
Exhaust valve:
1. Shims 2,40 and I measured 0,28
2. Shims 2,65 and I measured 0,27
3. Shims 2,60 and I measured 0,18
4. Shims 2,40 and I measured 0,27
Inlet:
No air gap...
I have talked with the workshop and he suggested two option for.
1. Step down the value to what I say he shall step down to....
2. He can adjust each valve to the clearness I want.
What shall I go for?
1. How can I figure out how much he shall take off ? shall he take all 8 then ?
Will I got problem to re-shims in the future, gap will get smaller and smaller?
2.
If he shall adjust the clearness by step down the valve, then I should have the same shims on all valves when I deliver the
parts to him? I will then get same air gap on all valves and same shims on all valves, I will then have a perfect starting point for future adjustment ? What shims should I install before I deliver the parts to him?
Have I understand these correct ? what is the best to-do?
Project:
Last edit: 06 Feb 2018 06:29 by gordone.
  • gordone
06 Feb 2018 23:33
#778349
I think I want to go for option where he tap off to wanted valve clearness, to avoid any more problem... I ask him to take of to much or less...
My only questions is then, Is it fine I just use the shims I have today or must I order some new?
I`m thinking of future valve clearness adjustment... I need to have something to adjust on... able to go up and down in shims sizes ??
What I have today:
2,4
2,65
2,55
2,45
2,75
2,7
2,7
2,7
Project:
