Wrong Carb Holder
- gordone
Wrong Carb Holder
20 Jan 2018 03:03 - 20 Jan 2018 03:13
No eBay APP ID and/or Cert ID defined in Kunena configurationI have a 750-H(X) Ltd 81 engine with VM24 carburetors (from 650CC).
I have order new carburetors holders 16065-1132 (HOLDER-CARBURETOR), but these was incorrect, please see picture of the new and old.
They are bigger in size and have not the vaacum pipe for carb tuning....
I guess the problem is I order carb holders for carbs original used for 750 engine and I need carb holders for VM24....
What order number shall I use, 16065-046 ?
So these will be identical to what I have?
Project:
Project:
Last edit: 20 Jan 2018 03:13 by gordone.
Re: Wrong Carb Holder
20 Jan 2018 05:35 - 20 Jan 2018 07:46
Those eebbaayy carb holders should fit. The brand is Tourmax. I would ask: where are they made?
When using them on a 750-4 engine. you may have to enlarge the bolt holes. maybe not, though.
K&L is another brand. made in Japan. K&L only makes the RH carb holders, so you have to use 4 RH.
Z1Enterprises.com. 1981 KZ650-H1 CSR. KL11-5444X2.
For reference you probably should use the 1981 KZ650-H1 CSR part numbers. LH = 16065-046. RH = 16065-047
Partzilla. 1981 KZ650-H1 CSR. Cylinder head.
Last edit: 20 Jan 2018 07:46 by martin_csr.
- gordone
20 Jan 2018 09:58martin_csr wrote: Those eebbaayy carb holders should fit. The brand is Tourmax. I would ask: where are they made?
Thank you, I will check and follow what is on the ebay the next days. I found some OEM on ebay also.
Project:
Project:
- gordone
22 Jan 2018 02:25
I have now purchased (attached) four new OEM, hope They will fit me good.
If they are identical to my old one, they shall be bolt on and working great...
Thank you all for your inputs !
Project:
Project:
