Inlet rubber (between carbs and inlet)
- gordone
09 Jan 2018 09:40
Please see attached picture, is these a problem? When I took the picture I was using some force / stress on the rubber..
so it`s don`t look like these in normal condition, as I see is not the damage on the rubber deep.
I think we will work for some years ?
I have noting who hold the weight of the carbs, its the rubber who take the weight, maybe these is a issue?
Project:
Project:
Re: Inlet rubber (between carbs and inlet)
09 Jan 2018 09:56
Replace them.
- gordone
09 Jan 2018 10:05SWest wrote: Replace them.
OK, I think I will use them for the summer season and then replace them. I`s not deep, but I see what you saying
you never know when they start to leak....
Project:
Project:
09 Jan 2018 12:38
They will leak at the head.
- KZB2 650
09 Jan 2018 12:52 - 09 Jan 2018 12:57
I agree with Steve ...... leaky holders are linked to a lot of problems on here. I'm sure new ones cured the off idle stumble I had for years with my smooth bores. I know things are adding up for you but they could turn out to be a real pain in the butt when you go to fire up your new motor and getting the off idle and low end smooth......
Also I've always let mine hang W/Pods but am going to rig up a simple piece of wire this spring off the frame to the back of the carbs to take a little weight off em.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 09 Jan 2018 12:57 by KZB2 650.
The following user(s) said Thank You: SWest, gordone
- gordone
10 Jan 2018 00:28
I have ordered new one
And I will find a solution for taking of some weight
Thank you all
Thank you all
Project:
Project:
