Head Gasket for Wiseco Piston 69.00mm
- gordone
04 Jan 2018 09:07 - 04 Jan 2018 09:09
Hi,
I have a 750-H(X) Ltd 81 engine, where I`m going to upgrade to Wiseco Piston 69.00mm / 810CC.
My question is what head gasket I shall go for, for best results over time...
I already have a OEM orginal gasket (750cc), but will that be a good solution?
I have checked Wiseco homepage:
www.wiseco.com/ProductDetail.aspx?ItemID...Year=1981&AppID=6915
Gasket W3163,
www.summitracing.com/int/parts/wis-w3163/overview/
These gasket are not identical as the OEM I have (see attached photo).
What shall I do? what will the best option be for me as a long term solution?
Gasket W3163,
Project:
Project:
Last edit: 04 Jan 2018 09:09 by gordone.
Re: Head Gasket for Wiseco Piston 69.00mm
04 Jan 2018 09:20
Use the Wiseco head gasket that comes in the big bore kit. It's made by Cometic, which isn't the best quality, but passable.
- gordone
04 Jan 2018 09:33Nessism wrote: Use the Wiseco head gasket that comes in the big bore kit. It's made by Cometic, which isn't the best quality, but passable.
But I haven`t other option then use Cometic gasket for these bigbore kit?
Project:
Project:
- zukdave
04 Jan 2018 18:55
I run the Cometic in my 810 kitted ZX750A1 (GPZ750) motor and never had an issue.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- gordone
04 Jan 2018 22:43
Thank you all.
I have now ordered Wiseco W3163 - Wiseco Head Gaskets, hope it will fit
Project:
Project:
