Start up engine after rebuild
- gordone
Re: Start up engine after rebuild
28 Apr 2018 17:18
Today have I taken a longer trip and the bile is working fine in general, but I experience some load alternation approx +/- 50% throotle.
I think has nothing todo with the RPM.
If I have throotle within 1/3 it goes stable and it increase stable and in the 3/3 range 60-70% it also looks to be steady. Have not tried more then 70% throtle get some more miles first.
Exampe:
Crusing with 30% throotle everyting is stable, increase up to aporox 50% it acclerated but it also give load alternation...
Increase throotle further its disepear ...
When it disepear I also got much more power, the throotle is not linear to force.
I hope these is understable to understand what I try to explain.
What can the problem be?
The load alternation is not so heave that I todo something with the throtle.. but I need todo something.
Thank you.
Exampe:
Thank you.
Project:
Project:
28 Apr 2018 17:52 - 28 Apr 2018 17:52
Carb jetting issues is my guess.
Last edit: 28 Apr 2018 17:52 by Nessism.
- gordone
28 Apr 2018 17:58Nessism wrote: Carb jetting issues is my guess.
In the overlap from pilot jet to main jet?
Main 112.5
Pilot 17.5
I remember I had something identical with the 750 orginal pistons, but then the problem was so small I dident do anything with it.
What shall I try with the jets?
Only the main I need to increase?
Project:
Project:
- KZB2 650
29 Apr 2018 08:27
What carbs are those....... I thought we talked about em but can't find it........Not sure but a Z750L motor on the net says it uses 32mm CV Keihin's but those are are not that. Thinking they might be 24mm slide carbs off a 650 by looking at them but not sure. Anyway the needle would supply the fuel in the mid range and might need to be raised a notch. Thinking your main and pilots should be damn close. I'd say get a few more miles on it and see what a few others think.
Also some might blame the pods VS the stock air box for the mid range being a little bit bit off but they've always worked good for me. ( won't argue about them not really producing much of a power increase) I mainly like the ease of getting them off and the looks. Sometimes a strong side wind will affect mid range range riding been talked about and I've seen that too.
Didn't really read your build thread all the way through till a few days ago and you did a really nice job on the motor, paint, going over things etc Have fun. Very much like the color and was thinking about something very close on my second tank and covers.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- gordone
29 Apr 2018 09:12 - 29 Apr 2018 09:15KZB2 650 wrote: What carbs are those....... I thought we talked about em but can't find it........Not sure but a Z750L motor on the net says it uses 32mm CV Keihin's but those are are not that. Thinking they might be 24mm slide carbs off a 650 by looking at them but not sure. Anyway the needle would supply the fuel in the mid range and might need to be raised a notch. Thinking your main and pilots should be damn close. I'd say get a few more miles on it and see what a few others think.
Not to offense none of you, all inputs and feedback is greatly appreciated !
I started a new threat just for these specific problem so more people can read about instead mixing it with the start up.
www.kzrider.com/forum/2-engine/608313-he...big-bore-engine-vm24
The carb is VM 24.
The needle height is one step higher? lower? then middle. one step so you get more fuel, should I try to take it one step further ?
I`m running the same setup I had with original 750 CC pistons.
I have added more info to the other threat.
Project:
Project:
Last edit: 29 Apr 2018 09:15 by gordone.
