1982 kz750e swingarm pivot bolt size
- Jon8329
08 Dec 2017 15:37
I can't find the pivot bolt size for my 82 kz750e I keep finding conflicting numbers any help would be great thanks
- Daftrusty
Re: 1982 kz750e swingarm pivot bolt size
08 Dec 2017 16:47
The pivot bolt is 16mm in diameter if that is what you are asking about.
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
The following user(s) said Thank You: Jon8329
09 Dec 2017 07:11 - 09 Dec 2017 11:19
Do you need a new oem part or just trying to find a suitable replacement? And what numbers are you finding?
According to the cross-reference at partzilla the same pivot bolt is used on all of the 650 & 750E/H models. and possibly other models as their x-ref is incomplete.
Partzilla >>>1982 KZ750-E3 >>> SHAFT,SWING ARM 33032-050 (NLA) .... (swing arm shaft = pivot bolt)
Last edit: 09 Dec 2017 11:19 by martin_csr.
- Jon8329
09 Dec 2017 09:29
I think I was looking at the pivot bolt size and the space between the frame is why I was getting mixed up don't need a new one I'm still putting together a plan for a swingarm and front end replacement along with wheels just trying to get the measurements to try and find something that will go in without to much fab.
- les holt
09 Dec 2017 10:20
16mm dia. thru bolt, 230mm or 9.055" frame width.
Les Holt
PDM
Les Holt
PDM
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
