Factory Ring gap for 79 kz1000
  • Rainolee
  • Rainolee's Avatar Topic Author
05 Dec 2017 17:35
#775624
Does anyone know the factory Ring gap for a 1979 kz 1000 ltd with stock bore of 70mm? I have a Nic in one of my cylinder sleeves and I'm going to be replacing them all they will be 70mm bore with nos Pistons with new rings
  • missionkz
  • missionkz's Avatar
Re: Factory Ring gap for 79 kz1000
05 Dec 2017 23:07 - 05 Dec 2017 23:29
#775629
Your piston and ring manufacturer should have that info supplied with the parts. When really active in this, I used to to figure a minimum of .1mm gap for every 24mm of bore.
And less then that for the second ring.
So, 70mm would be .29mm min
I just looked and my manual says .30mm to .50mm and .80mm as max limit.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 05 Dec 2017 23:29 by missionkz.
  • kevski
  • kevski's Avatar
06 Dec 2017 10:12
#775653
Top 2 rings new 0.4 mm or 0.016 inch, maximum wear 0.8mm or0.032 inch
