- Thank you received: 118
6-speed Transmission Swap Instructions
- ghostdive
02 Jun 2022 07:01 #868029
by ghostdive
2001 ZX-6R
Replied by ghostdive on topic 6-speed Transmission Swap Instructions
Yes, on my 750. Honestly I miscalculated the results I would get - somehow I had thought that it would be like my standard 5-speed transmission with an overdrive to get better fuel mileage on the freeway.
I wouldn't say that the current setup is unusable, and it might even be preferable for some, but it's a lot of work and commitment. Also, if you've got a shaft driven 750 with a 16" rear wheel, it might be a little much - rough guess that you would be at 6k going 70mph in that case.
Anyway, even though the results aren't what I had hoped for, I'm glad that I did it so that people know that it can be done and know the results to expect. Plus it's fun.
2001 ZX-6R
- ThatGPzGuy
- Thank you received: 385
03 Dec 2022 10:50 #877460
by ThatGPzGuy
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Replied by ThatGPzGuy on topic 6-speed Transmission Swap Instructions
I bought a KZ550 gear cluster right after Daftrusty posted this for when I tear my GPz down for an 810 kit.
It's on! Thanks again, Daftrusty.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ThatGPzGuy
11 Feb 2024 09:29 #895121
by ThatGPzGuy
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
So, getting back to this after a long delay. I have been test fitting the transmission and I would like to point out the 750 roller bearing has to be used with the 750 input bushing. It's NLA but I was able to find NOS on eBay. It's fairly obvious but should be pointed out since you have to remove it from the 750 cluster. I missed it when I was putting things together for test fitting. The attached pic shows the correct needle bearing the 550 needle bearing is smaller. Also, what tool should be used to take these circlips on and off without damaging them?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- daveo
- Thank you received: 684
11 Feb 2024 10:29 #895127
by daveo
Me too
1982 KZ1100-A2
Replied by daveo on topic 6-speed Transmission Swap Instructions
...thought that it would be like my standard 5-speed transmission with an overdrive to get better fuel mileage on the freeway.
Me too
1982 KZ1100-A2
- Thank you received: 2388
11 Feb 2024 10:48 #895131
by Wookie58
Replied by Wookie58 on topic 6-speed Transmission Swap Instructions
Given that the cluster is intended for a smaller motor could you not change the sprocket ratio to get the cruising revs you want with the benefit of the six gears which should pull better through the box
The following user(s) said Thank You: chopper1963
