Temperature
- gordone
Temperature
26 Nov 2017 13:24
I have Kawa 750 750-H 81, and planning to paint the engine.
I wondering if you know how hot the motor covers can be on the left and right covers?
Cover over the gearbox and the cover over the alternator and the cover over the clutch on the right side,
they cannot be so hot as the block?
100 Celsius ? more ?
Thank you for your feedback.
Project:
Project:
Re: Temperature
26 Nov 2017 19:28
There is an old thread by member OMR where he posted temperature readings on various areas of hus KZ1000 engine.
- gordone
Re: Temperature
26 Nov 2017 22:48TexasKZ wrote: There is an old thread by member OMR where he posted temperature readings on various areas of hus KZ1000 engine.
Thank you, will search for it.
Project:
Project:
- gordone
Re: Temperature
27 Nov 2017 04:46TexasKZ wrote: There is an old thread by member OMR where he posted temperature readings on various areas of hus KZ1000 engine.
Are you sure his username is "OMR", I tried to search but, dident found any post by "OMR" ?
I will try search another ways.
Project:
Project:
Re: Temperature
27 Nov 2017 05:19
I am sorry. His user name is Old Man Rock. We just called him OMR for short. :whistle:
Re: Temperature
27 Nov 2017 06:07 - 27 Nov 2017 06:11
Scroll down about seven posts in this thread.
www.kzrider.com/forum/2-engine/453478-oi...possibilities#453667
Keep in mind that this is for a modified 900 that lives in the Arizona desert and the measurements are in Fahrenheit.
Last edit: 27 Nov 2017 06:11 by TexasKZ.
Re: Temperature
27 Nov 2017 09:16 - 27 Nov 2017 09:18
If you plan on painting the entire engine, I don't know what you should do.
The engine covers get pretty hot. I painted the generator cover & pulsing coil cover with Duplicolor engine paint, but any high temperature paint will probably be good. Duplicolor. VHT. Eastwood, Casewell. etc. even Rustoleum bar-b-que grill paint.
I did a very quick job on the engine covers several years ago, and they still look very good.
Duplicolor high temp engine paint. gloss black.
cleaned & polished quickly. put a very light coating of grease on the raised letters --- a little grease on finger tips,
then lightly pat the letters. very easy. quick haphazard masking tape around the perimeter then light grease where needed.
Sprayed parts, then allowed about 1 hr dry time, removed masking tape & wiped off grease. let parts cure overnight,
then baked engine covers in low temp oven. 20 mins @ 170o F + 30 mins @ 225o F
Last edit: 27 Nov 2017 09:18 by martin_csr.
- gordone
Re: Temperature
28 Nov 2017 08:09
Thank you all, I think have a plan now.
Prime the side covers with, these primer (1200 ºC):
www.hirschauto.com/12-OZ-HI-TEMP-AEROSOL...productinfo/PRIM+HT/
And then paint the whole engine with (980 ºC)
gasolin.no/index.php?main_page=product_info&products_id=213
Will sand down the chrome covers on left and right side good before I apply the primer.
A plan ?
A plan ?
Project:
Project:
- kevski
Re: Temperature
30 Nov 2017 01:56 - 30 Nov 2017 01:58
If you actually have chrome covers you would be better to have them stripped, because even sanded chrome does not hold paint well, if you have access to 69% nitric acid this will strip the chrome properly, just handle the stuff with respect and research the do's and don'ts of acid handling.
Last edit: 30 Nov 2017 01:58 by kevski. Reason: spelling mistake
