Oil Pan Compability
- Shoey949
Oil Pan Compability
10 Jul 2006 09:11
Was wondering if an '81 KZ550 oil pan is the same as an '81 GPZ 550 D1? Kawasaki shows two different part numbers, but from pictures they look exactly the same.
Thanks,
Nate
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
Grand Rapids, MI
- btchalice
Re: Oil Pan Compability
10 Jul 2006 09:52
that could be one black and one aluminum. check to see if they use the same gasket
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- Mcdroid
- Gone Kwackers
10 Jul 2006 11:33
Hmm...not only do the oil pans have different numbers, the gaskets also have different numbers. I'd be leery until you get positive confirmation from a KZR member.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- trippivot
11 Jul 2006 05:52
1981 kz 550 ltd,standard,GPz use gasket#11060-1057
the pan # are 49034-1002 for kz ,ltd
pan# 49034-1011 GPz
same gasket = same basic cover
pan# 49034-1011 GPz
- Speedbump
11 Jul 2006 16:39
The oil pans for a GPZ have fitting for an oil cooler. They should fit just fine.
Speed
Speed
- Speedbump
11 Jul 2006 16:40
holy triple post Batman!!!!
Post edited by: Speedbump, at: 2006/07/11 19:41
- Speedbump
11 Jul 2006 16:40
do de dooooo
- btchalice
11 Jul 2006 17:00
you must have tripped on a speed bump:laugh: :laugh:
- CoreyClough
- GPz550 Addiction
11 Jul 2006 18:18
I agree with speedbump, as the GPz has the modifications for the oil cooler. If you need one, now would be a good upgrade for an oil cooler. I see parts for Gpz550's on ebay quite a bit.
'85 GPz550(ZX550-A2)
- Shoey949
13 Jul 2006 11:02
no I'm trying to fit a kz pan on a gpz bike so it would be a downgrade as I would lose the oil cooler which I had not seen before.
Grand Rapids, MI
Grand Rapids, MI
