Top end gasket kit, KZ1100 which one?
  • M_a_t_t
  • M_a_t_t's Avatar Topic Author
22 Oct 2017 20:39
#773514
What kit do you guys recommend? I was going to just order the one from z1, but figured I would see if there was something better out there. Or should I just get the full rebuild gasket set for $16 more and just save the other gaskets for back up? I am also planning to get viton valve guide seals instead of what comes with the kit.
Thanks, Matt
www.z1enterprises.com/gasket-set-kz1100-81-83-top-end-set.html
www.z1enterprises.com/valve-stem-seals-u...rsal-7mm-stem-1.html
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • Nessism
  • Nessism's Avatar
  • M_a_t_t
Re: Top end gasket kit, KZ1100 which one?
23 Oct 2017 07:10
#773530
Are they available anywhere other than a dealer? I can't seem to find any.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
  • Nessism
  • Nessism's Avatar
23 Oct 2017 07:20
#773531
Yes dealerships, or an online dealership source. You may want to try Partzilla.com and make a list of everything you need. You will have to go page by page through the fishe to be sure you don't miss anything. Once you gather up all the part numbers then you can search ebay to try to find a better price. Particularly for common gaskets like the head gasket and valve cover gasket. Also, get some Viton valve stem seals. They are one of the very few aftermarket parts that are better than the originals. A member on the forum sells sets.
The following user(s) said Thank You: KZB2 650, M_a_t_t
  • KZB2 650
  • KZB2 650's Avatar
23 Oct 2017 07:22 - 23 Oct 2017 07:25
#773532
Ebay using the part number, Partzilla, Z1 and Cheap cycle parts got me most of my stuff. Edit Nessium beats me again.:lol:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 23 Oct 2017 07:25 by KZB2 650.
The following user(s) said Thank You: M_a_t_t
  • M_a_t_t
31 Oct 2017 18:56
#774067
Is it worth getting OEM exhaust gaskets?
Thanks, Matt
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
  • nads.com
  • nads.com's Avatar
06 Nov 2017 08:46
#774266
The valve seals in the kit caused my bike to burn so much oil i eventually got tired of adding oil and after 2yrs i fried some bearings in the crank. The rubber seals were the consistancy of bubble gum. The paper gaskets? Good luck on using those as well. Ive never seen such cheap stuff and theres much more where it all comes from. I lost alot of respect for z none after seeing what they sell and what it cost you. Very nice people though. :huh:
  • M_a_t_t
06 Nov 2017 14:42
#774273
I've started ordering OEM gaskets, except for some viton valve seals from z1
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
  • KZB2 650
  • KZB2 650's Avatar
06 Nov 2017 15:24
#774274
Although I've had good luck with the KL exh gaskets Z1 sells the Suzuki (thicker seal) that a few on here like better........ would have bought them if I had to do it over but was too late to change the order.
1978 KZ650 b-2
