So I got my 5th bike. a 1977 KZ650. Question:
- JWKZ750
05 Oct 2017 17:17
Here are pics. Anyone have any foolproof ideas of how to get the oxidation off the engine (its grey and lumpy)?
See pics:
See pics:
Re: So I got my 5th bike. a 1977 KZ650. Question:
05 Oct 2017 20:33
Vapor blasting will do it. So will many hours with sandpaper, WD40, and aluminum polish.
- Nerdy
06 Oct 2017 06:31
I've been testing a brass wire brush in a cordless drill for cleaning up the cooling fins and top end. So far it seems to work pretty well and gives a satin-type finish. (Brass doesn't damage aluminum like a steel brush would.)
You wouldn't want to use it on the clutch cover and other smooth surfaces, though. Those are candidates for polish.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- KZB2 650
06 Oct 2017 10:43 - 06 Oct 2017 10:44
I've gone over my covers with 400 and 600 grit over the years with water and a few drops of soap then followed up with Mothers polish.......... recently found hitting it with 1000 then 1,500 grit lastly really helps bring the shine out before hitting it with polish. Ed uses a couple of products I'm sure he will chime in on and you can't argue with his results but since I've had the Mother for years I was too cheap to switch.
Just was a thread on sealing the shine in with clear coat and there is a lot of sealers out there too but I'll probably just plan on hitting them once a month quick now that I've got em pretty nice. My head is still very good and since I have painted the block black for years I don't have to worry about that hard to work fin area........ Like that green (the darker green too) please be sure to give us some pics after you get it shined up.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 06 Oct 2017 10:44 by KZB2 650.
- bluej58
06 Oct 2017 17:26 - 06 Oct 2017 19:45
78 KZ1000 A2A
Last edit: 06 Oct 2017 19:45 by bluej58.
- ThatGPzGuy
06 Oct 2017 17:37
SOS pads on the bits with corrosion. You can use it on the shinier bits but with a much, much softer touch. Soda blasting is an option if you have access to one. The polished parts will need the full sandpaper to buffing wheel treatment depending on how far you want to take it.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- JWKZ750
06 Oct 2017 20:43bluej58 wrote: I like WD-40
www.kzrider.com/forum/6-paint-a-bodywork...ore-the-metal#632029
Wow, this is super helpful! Thanks!
- bluej58
07 Oct 2017 18:49
Simple green straigt is a good way to start.
It works quickly on dry grime but it also likes to eat aluminum, so I keep spraying the motor to make sure it doesn't dry out ,
and after about an hour I wash it off with soapy water then rinse with clean water.
After it drys I spray it down with WD-40 and start with the Scotchbrite
78 KZ1000 A2A
- JWKZ750
07 Oct 2017 19:02bluej58 wrote: Simple green straigt is a good way to start.
Ironically I have some simple green in the house. Thanks so much!
- bluej58
07 Oct 2017 19:08
If you have a scrub brush that would help too
78 KZ1000 A2A
- Nerdy
18 Oct 2017 19:22bluej58 wrote: Simple green straigt is a good way to start.
There is a purple version of Simple Green which is labeled as safe for all metals. Home Depot and other places carry it.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
18 Oct 2017 19:35
After most of any heavy corrosion has been removed yo can use either (or both) of the products below to make the aluminum shine. The S-100 is a polishing cream, the X-TREEM is polishing wadding. They both work very well, but of course the more rubbing you do with them the better the engine looks. Ed
