Clutch
  • Kawi-problems23
  • Kawi-problems23's Avatar Topic Author
  • 1980 Kawasaki kz250 single cylinder
Clutch
30 Sep 2017 13:49
#772050
Hey. I have a kz250 that just keeps causing problems, first of all my clutch isnt engaging at all the clutch rod doesnt seem to move or something.
Seccond the engine starts and stalls as soon as I let go of the throttle and depending on where the choke is no matter how much gas i give it it doesnt rev higher plus its really loud.
Any advice would help alot. Thanks
  • TexasKZ
  • TexasKZ's Avatar
Re: Clutch
30 Sep 2017 20:39
#772075
If the clutch will not engage at all (acts like the trans is in neutral), the clutch cable could be adjusted way too tight, the release mechanism could be broken or rusted. Much less likely, the clutch hub nut could be loose, or the clutch could be missing.
Carb may need a thorough cleaning and adjustment, and the carb holder may need replacing.
Install a muffler.
Has all the routine maintenance been performed? Is the factory air box in place?
  • martin_csr
  • martin_csr's Avatar
Re: Clutch
01 Oct 2017 05:52 - 01 Oct 2017 07:34
#772082
The KZ250 clutch release is different from most KZs, but it's kind of similar to some of the shaft drive models. With that type you usually adjust the cable & if that doesn't work the cable may be stretched so you'd replace the cable. This is assuming the clutch release mechanism is properly installed & not damaged.
I don't know anything about the 250, but from the diagrams at Partzilla, the clutch release lever mates to the clutch release shaft. check that the splines aren't stripped & make sure the bolt is tightened properly. There's another bolt that appears to be a dog bolt. The end of the bolt fits into a groove on the clutch release shaft & I think it keeps the shaft from moving up & down.
There's a long push rod & a short push rod. The short push rod has teeth that mesh with the clutch release shaft. make sure the teeth on each part aren't worn or broken. Maybe the short push rod is missing?
Last edit: 01 Oct 2017 07:34 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
Re: Clutch
01 Oct 2017 06:22
#772087
Just to be sure we are on the same page, when you are riding down the road and you are not touching the clutch lever, the clutch is ENGAGED and transmitting power to the transmission output shaft.
When you squeeze the clutch lever, the clutch cable pulls the release mechanism, thus DISENGAGING the clutch so that the motorcycle can be stopped with the engine running and the transmission in gear.
Not squeezed = engaged
Squeezed = disengaged
You should not touch the throttle when starting the engine. The starting and running problems you describe could be caused by several problems, such as clogged pilot circuits, leaking carb holder and adjustments that are way out of spec. If I had to bet on a single cause, I'd put money on a recently removed air box.
  • Kawi-problems23
Re: Clutch
01 Oct 2017 10:57 - 01 Oct 2017 11:10
#772101
Alright texaskz i have adjusted the clutch cable and it still wont disengage so i will try to find the clutch hub nut and what does a air box look like? And when i pull the clutch lever the clutch does not engage
Last edit: 01 Oct 2017 11:10 by Kawi-problems23. Reason: I
  • Kawi-problems23
Re: Clutch
01 Oct 2017 11:01 - 01 Oct 2017 11:02
#772102
Okay martin_csr i will try to locate these bolts and i cant find the short push rod does that go infront of the long one or do you know where i can find it?
Last edit: 01 Oct 2017 11:02 by Kawi-problems23.
  • TexasKZ
  • TexasKZ's Avatar
Re: Clutch
01 Oct 2017 13:15 - 01 Oct 2017 13:20
#772110
Kawi-problems23 wrote: Alright texaskz i have adjusted the clutch cable and it still wont disengage so i will try to find the clutch hub nut and what does a air box look like? And when i pull the clutch lever the clutch does not engage
When you pull the clutch lever it is not supposed to engage. When you pull or squeeze the lever it is supposed to disengage.
Forget the hub nut until tou are absolutely sure that the release mechanism is functioning properly.
An exploded view of the air box is at the link below. It is what the air cleaner goes in.
www.kawasaki.com/Parts/PartsDiagram/142244/1980/KZ250-D1
Last edit: 01 Oct 2017 13:20 by TexasKZ.
  • TexasKZ
  • TexasKZ's Avatar
Re: Clutch
01 Oct 2017 13:26
#772112
Kawi-problems23 wrote: Okay martin_csr i will try to locate these bolts and i cant find the short push rod does that go infront of the long one or do you know where i can find it?
The release mechanism is numbers 10 - 15
www.kawasaki.com/Parts/PartsDiagram/142237/1980/KZ250-D1
  • TexasKZ
  • TexasKZ's Avatar
Re: Clutch
01 Oct 2017 13:32 - 01 Oct 2017 13:47
#772113
Last edit: 01 Oct 2017 13:47 by TexasKZ.
The following user(s) said Thank You: Kawi-problems23
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Clutch
01 Oct 2017 14:53 - 01 Oct 2017 15:03
#772119
The KZ 250 D1 has a unique clutch actuator gear push rod system, this is Kawi-problems23 mayor problem.
my thought is:
He has to adjust the gear on rod #12 with gear push rod #14.
Loosen screw #17, pull out #12, push in #14 to get in touch (pressure)push rod #15 and then put in #12 to a 90 - 100 degree angle.
or readjust lever #11 on rod #12
Last edit: 01 Oct 2017 15:03 by Scirocco.
  • Kawi-problems23
Re: Clutch
01 Oct 2017 16:09
#772136
Thank you so much for all the advice and the service manual everyone i am going to look at the clutch again right now.
  • martin_csr
Re: Clutch
02 Oct 2017 06:12 - 02 Oct 2017 06:14
#772174
What exact year & model is your 250? Was the clutch working fine before the problem came up?
From the diagrams the 80-81 clutch release is completely different from the later models.
Last edit: 02 Oct 2017 06:14 by martin_csr.
