Clutch push rod problem
Re: Clutch push rod problem
02 Oct 2017 05:05
Thanks for the update.
Don't feel bad, we've all been there.
- Nerdy
02 Oct 2017 14:38MrLantz wrote: Well. I guess it's my turn to admit the problem was... ME!
As TexasKZ said, we've all been there.
Again, the bike has been without oil for a couple of months. Once everything fires up and starts moving (heat and so on) I'm sure the clutch will pop out of it's slumber. If not I will revive this thread again
Please remind yourself somehow to put oil back in it before you crank it over. I like to put blue masking tape over the ignition keyhole and on the oil cap - that way I have visual reminders from two different directions.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
02 Oct 2017 15:18 - 02 Oct 2017 15:23
Fine that you fix your self made problem, we're all supposed to learn from our mistakes sometimes.
Yes Nerdy, not that someone else get the stupid idea and try to start the bike.
I would remove the fuses and disconnect the battery.
Last edit: 02 Oct 2017 15:23 by Scirocco.
