overhaul engine top
  • gordone
  • gordone's Avatar Topic Author
overhaul engine top
25 Sep 2017 08:56 - 25 Sep 2017 08:56
#771652
Hi,
I have a GPz750 engine, the engine is running fine, but I shall replace the top gasget and when I do these
I want to rebuild the engine as the same time.
1. Honing cylinders
2. replace the piston rings
3. More I should do with the cylinders / pistons?
But what about the top, I have been informed I should replace the sealigs for the valves,
but should I do more? replace the piston springs? do someting with the valve to make them good as new and 100% air tight ??
more ?
Thank you for sharing your acknowledge for overhaul the engine on the top side.
Project:
Last edit: 25 Sep 2017 08:56 by gordone.
  • kevski
  • kevski's Avatar
Re: overhaul engine top
25 Sep 2017 10:17
#771658
Why would you do all that work if it runs fine, we have a saying in the UK, if it ain't broke don't fix it.
25 Sep 2017 11:48 - 25 Sep 2017 11:49
#771663
kevski wrote: Why would you do all that work if it runs fine, we have a saying in the UK, if it ain't broke don't fix it.
We have the same saying here in the US, for the same reason.
I don't understand the the logic in taking apart an engine that is running fine. Since it runs fine just ride and enjoy it. If it's a matter of curiosity I suggest it makes more sense to buy an inexpensive engine that does not run and take it apart to fix it. Ed
Last edit: 25 Sep 2017 11:49 by 650ed.
  • kevski
  • kevski's Avatar
25 Sep 2017 12:49
#771665
Do you also share the K.I.S.S analogy of Keep It Simple Stupid.
25 Sep 2017 14:40
#771675
Yes, we do. Although I sometimes forget to do it. :laugh: Ed
  • gordone
26 Sep 2017 04:18
#771707
hehe :) and I will save money also :)
The engine using oil, but I can off course add in between.
It was more that I want to have a hobby and like to learn :) and like to fix the whole bike to be 100%, but off course I can start with the cosmetic of the engine first. and then overhaul other part of the bike as the brake caliper etc.. . :)
Let me think on it :)
Project:
  • gordone
26 Sep 2017 08:55 - 26 Sep 2017 08:56
#771721
I forgot one thing, I need to replace the head gasket en the o-rings on top of the block, it`s no problem just replacing these?
The gaskett under the block will not start leaking or something?
Project:
Last edit: 26 Sep 2017 08:56 by gordone.
  • KZB2 650
  • KZB2 650's Avatar
26 Sep 2017 14:20 - 26 Sep 2017 14:20
#771737
That's the trouble many times you will break the base gasket loose removing the head and if you don't replace it it will leak and then you need at a min rings and a hone..... and since you have the head off seals and a lap or maybe grinding and hopefully the guides are good..... one thing leads to another.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 26 Sep 2017 14:20 by KZB2 650.
  • gordone
26 Sep 2017 21:43
#771860
I don^t want todo thes two times, so I think I will go for the plan...
honing cylinders, replace rings, replace seals valves, but what is lap, grindings, guides?
lap = to make the valves 100& air tight ?
grinding= if the surface on block and top is not 100% align, so you will not get it 100% tight when you replace the gasket?
guiding = the bolts who fasting the top?
Project:
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
27 Sep 2017 05:42 - 27 Sep 2017 15:56
#771870
gordone wrote: I don^t want todo thes two times, so I think I will go for the plan...
All valve related
Make sure valve guides are snug to the valve stems ( No extra play )
Lap and or grind valves and or valve seats to insure perfect seating and seal to valve seats.
Block ( cylinder ) and head are almost never ground flat during a rebuild
Read factory service manual until all needed work is clear to you
Dave B) B) B)
Last edit: 27 Sep 2017 15:56 by Street Fighter LTD.
  • gordone
27 Sep 2017 08:50
#771880
Thank you for all information !
I have one more questions right now, what is the chance the base gasket under the block will start leak If I only replace the top gasket and the o-rings (oil channel) in the top?
Project:
  • Moderator
  • Moderator
27 Sep 2017 15:58
#771893
gordone wrote: Thank you for all information !
Chance of a leak at base gasket is 50/50 based on your ability to not disturb seal and fit between cases and block.
