KZ1000 Frankenstein motor
- KGKZ1K
21 Sep 2017 15:31 - 21 Sep 2017 15:32
Good Afternoon All,
The weather has started to turn and I am getting my winter projects in order...I am wanting to do a little performance upgrading on my 82LTD as my first winter program..
It is currently bone stock J motored(minus V &H Meg with no baffle and stage 1.5 jetting)
My questions are
1- I have a couple 1100 jugs sitting on the shelf and am looking at aquiring a complete 84 GPZ1100 head.
Do I need to run GPZ specific pistons (believe them to have larger wrist pins??) or can I run J motor 1100 pistons with this head?
2- I am planning on running either 1130 or 1170 pistons based on availability... will 29 smoothies provide enough carb for a 84 GPZ head/cam combo on an 1171 cc 10.5:1 comp motor?...or just break the bank and go for the RS34'S ?
Thanks all for your time and any help!
Cheers
Kris
My questions are
Cheers
Kris
1980 kz1000 LTD
1982 Kz1000B
1980 honda cm400
2x 1993 zx7
1991 zx7 project
1978 km100
1979 'zuk PE250
1993 yz125
....all kinds of other cool shit
1982 Kz1000B
1980 honda cm400
2x 1993 zx7
1991 zx7 project
1978 km100
1979 'zuk PE250
1993 yz125
Last edit: 21 Sep 2017 15:32 by KGKZ1K.
- daveo
Re: KZ1000 Frankenstein motor
22 Sep 2017 17:07
You may find something of interest in the following post:
www.kzrider.com/forum/2-engine/596933-ca...un-this-on-my-engine
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: KGKZ1K
- KGKZ1K
22 Sep 2017 22:33 - 22 Sep 2017 22:36daveo wrote: You may find something of interest in the following post:
Thanks for the link Dave...
Are you running stock Bs34's?
...and is the power increase worth the effort/cost?
Edit!...by worth the cost I am referring to the head upgrade(as opposed to the standard 'J' head)...i realize power costs and it's pay to play...but these heads are bringing serious coin at the moment.
1980 kz1000 LTD
1982 Kz1000B
1980 honda cm400
2x 1993 zx7
1991 zx7 project
1978 km100
1979 'zuk PE250
1993 yz125
1982 Kz1000B
1980 honda cm400
2x 1993 zx7
1991 zx7 project
1978 km100
1979 'zuk PE250
1993 yz125
Last edit: 22 Sep 2017 22:36 by KGKZ1K.
- daveo
23 Sep 2017 10:21 - 23 Sep 2017 10:34
Had BS34's, but RS34's went on last year. Unlike BS34's, the RS carbs have more jetting-tuning options, designed for use with pod filters or stacks.
If you go with RS carbs, the throttle system will need to be changed to a twin-cable setup. Also I found that an on-off petcock works better for fuel management than the vacuum unit that originally came with the bike.
For air-flow, velocity stacks tap a modified semi-original air box, that still utilizes the original crankcase breather system.
It works...
The effort was definitely worth it, and I would do it again the exact-same way.
It works...
Last edit: 23 Sep 2017 10:34 by daveo.
