Clutch cable replacement kz550
  • Logan
  • Logan's Avatar Topic Author
19 Sep 2017 13:36
#771248
So I followed all of the directions for replacing the clutch cable, but when i put everything back together, the clutch slips. Even with everything adjusted out the engine only begins to disengage. I thought it was the return spring on the clutch release, but the problem persists
1982 KZ550 LTD POS
  • martin_csr
  • martin_csr's Avatar
Re: Clutch cable replacement kz550
19 Sep 2017 15:36
#771260
Did you only adjust the cable or did you also adjust the clutch?
The following user(s) said Thank You: Logan
  • Hawghunter
  • Hawghunter's Avatar
27 Jun 2020 14:02
#829122
I broke my cable today so installing new one soon.
What do you mean by
“everything adjusted out” ?
1981 KZ550-A2
touring Red Rocks of Arizona on my KZ Red Rocket
  • Mikaw
  • Mikaw's Avatar
27 Jun 2020 14:13
#829124
Hawghunter wrote: I broke my cable today so installing new one soon.
What do you mean by
Not sure if it just, but I do know that when checking post on cell phones you don’t see the posted dates... not your fault. But I wanted you to know this post was last updated September of 2017.... chances of getting a reply are not strong...
  • Hawghunter
27 Jun 2020 15:12
#829132
Thanks. I wondered why there was no date.
1981 KZ550-A2
  • loudhvx
  • loudhvx's Avatar
27 Jun 2020 16:33 - 27 Jun 2020 16:33
#829150
Here's are some notes on the clutch adjuster for the 81 and later 550's.
Last edit: 27 Jun 2020 16:33 by loudhvx.
