KZ440 LTD leaking everywhere!
- KZ420
19 Sep 2017 11:58
Hey guys, new forum member here.
Last year I bought a KZ440 LTD and have recently been riding it after finally replacing the battery. I've been noticing after long rides that there has been fuel leakage on the front of the engine. I was confused for a while but then I found that there was a significant amount of fuel leaking where the header meets the exhaust on the left side. Also, looking at my exhaust after riding, the left exhaust tip is covered in fuel while the right is perfectly dry.
I ran the engine and then unplugged the right spark plug to see if the engine acted differently ( incorrect firing of the piston or something), and the engine sputtered and died. So I figured the cylinder was firing fine. I figure there is a valve stuck or something that's letting fuel leak out, what do you guys think, and what approach should I take? If you guys want I can post some pictures later.
- Nebr_Rex
Re: KZ440 LTD leaking everywhere!
19 Sep 2017 17:28
pics?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- KZ420
19 Sep 2017 18:09
I'll post some tomorrow as it's dark outside right now and I wont be able to take decent pictures.
