Do these plugs look LEAN to you?
  • JWKZ750
  • JWKZ750's Avatar Topic Author
Re: Do these plugs look LEAN to you?
23 Aug 2017 12:04
#769549
So i got the ThermoDipstick today. Should help me keep tabs on the engine heat.
  • zukdave
  • zukdave's Avatar
23 Aug 2017 16:01
#769569
I don't go by a color chart because most where made when fuel was leaded and unleaded fuel does not color plug's the same.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Aug 2017 16:26
#769573
How do a perfect spark plug look like with unleaded fuel.
Some pics would be nice, i have to know/learn the unleaded fuel reference spark plug color now for future posts like this.
  • zukdave
  • zukdave's Avatar
23 Aug 2017 17:08
#769578
I run 125 mains in a set of VM29's on my 810cc motor and they are almost white after a plug chop done right
After street riding for a while they get a little tan color to them.
IMHO if you have a modded motor buy a Colortune and learn to use it.
When I got mine I stuck it in an old Brigg's lawnmower and played with the choke to make it go rich or lean watching the color change.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Aug 2017 17:29
#769582
or by an O2 sensor kit like Autotune
  • zukdave
  • zukdave's Avatar
23 Aug 2017 18:58
#769603
Autotune only works on a EFI motor what you're thinking is a WEGO type setup that data log's off an 02 sensor
then down load the info. I think a WEGO setup run's a little over $400 buck's a color tune is about $80 buck's
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Aug 2017 19:18
#769605
Thanks for the info, get a thought for the long-term memory.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
23 Aug 2017 19:44
#769607
Keep in mind that not all exhaust changes require jetting changes. Not saying yours does not but not all do. You are IMO much more likely to require jet changes when you alter the intake.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • JWKZ750
23 Aug 2017 20:04
#769612
gd4now wrote: Keep in mind that not all exhaust changes require jetting changes. Not saying yours does not but not all do. You are IMO much more likely to require jet changes when you alter the intake.
Well the DUMB OP put PODS on the damn thing. What an idiot.
  • 80B4
  • 80B4's Avatar
26 Aug 2017 15:41
#769835
Modern pump gasoline has so many additives it is no longer accurate to use plug color to fine tune carb jetting. I have my bikes run on a dyno and checked with an exhaust gas sniffer when Im close to final jetting.
Race fuel is a different thing all together.
1980B4 1000
1978 Z1R
1978 B3 750
