76 kz900 Overheating
  • FuelnFlamez
  • FuelnFlamez's Avatar Topic Author
09 Aug 2017 17:48 - 13 Aug 2017 12:52
#768657
Hi, My bike runs great, my question is why is it overheating and is there anything i can do about it i heard that i can't ride it daily but would like to ride it as long as I can without it overheating any feedback would be thankful
76 Kz900 A4 custom
New front forks
mono shock swingarm
73mm piston kit - 1105cc
Dyna s ignition & coils
Pods
Vance & Hides 4 into 1 exhaust with baffle
Suzuki gs1000 VM28 carbs
Main jet - 130
Pilot jet - 17.5
Air Jet - 2.0
Needle 5DL31 - 4
Float bowl height - 26mm
Air screw - 1 1/4 turns out
Pilot fuel screw - 2 turns out
Last edit: 13 Aug 2017 12:52 by FuelnFlamez.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 76 kz900 Overheating
09 Aug 2017 18:02
#768658
Timing too advanced?
The following user(s) said Thank You: FuelnFlamez
  • baldy110
  • baldy110's Avatar
09 Aug 2017 18:16
#768659
What makes you think it's overheating?
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
09 Aug 2017 18:17 - 09 Aug 2017 18:21
#768660
Might the carburetor size have something to do with it?
Just a thought...:unsure:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 09 Aug 2017 18:21 by daveo.
  • FuelnFlamez
09 Aug 2017 18:30
#768661
I took a ride 5 minute ride by the time I got back to my driveway it was realy hot and cutoff and when i tried to restart it it sound like the battery was dead or cold start but starts after it seats for a while.
  • FuelnFlamez
09 Aug 2017 18:32
#768662
I Don't know.
  • spdygon
  • spdygon's Avatar
09 Aug 2017 19:29
#768670
Piston kit 10.5-1 compression?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • FuelnFlamez
09 Aug 2017 19:35
#768672
What do you mean can you explain.
09 Aug 2017 19:44 - 09 Aug 2017 19:48
#768674
Check list from FSM:
Engine oil level too low
Ign timing maladjusted
Carbon built up in combustion chamber
Brake dragging
Clutch slipping
Intake manifold broken or clamp loose
Main jet clogged
Float level too low
Has clear-tube test been performed to assure correct fuel levels (not too low)?
Condition of engine oil?
Tires under-inflated?
Clogged oil pump screen or mafunctioning oil pump?
Good Fortune! :)
Last edit: 09 Aug 2017 19:48 by Patton.
10 Aug 2017 05:19
#768696
What spark plugs are you using and what do they look like? Are the insulators too white? You may want to consider using a Gunson Colortune to check that the fuel mixture is not too lean. Ed
  • Nessism
  • Nessism's Avatar
10 Aug 2017 06:01
#768699
Is there a shop you can take the bike to and get it dyno tuned and properly jetted? Also, if your pods are those cheap emgo jobbies I'd replace them with some real K&N's.
  • baldy110
  • baldy110's Avatar
10 Aug 2017 08:13 - 10 Aug 2017 14:27
#768711
Your jetting seems right for the mods you have if the carbs are the stock VM26 or VM28. Air cooled engines rarely overheat to the point the die and cannot restart.. I have seen one example of that and it turned out the owner had run the bike super low on oil so there was also lots of engine damage.
I wouldn't assume yours is overheated, it's air cooled and if you are used to water cooled engine then yes you might think it's hot but in reality it's not. For example I built up an 82 Kz1000R with an 1175 cc high compression piston, ported head, performance cams, Mikuni RS36 carbs, ect.. The thing put out well over 100 HP, I rode it in over 112 temps and it never overheated and I rode it hard. These engines were used by the CHP for decades due to their reliability so don't let people tell you cannot use these as a daily rider.
Along with what everyone else has said, Check you battery and it's connections, make sure they are clean, do a complete tune up including checking valve clearances.
[IMG
Last edit: 10 Aug 2017 14:27 by baldy110.
