wiseco 1075 different rings?Pistons?
  • clarkster
  • clarkster's Avatar Topic Author
Re: wiseco 1075 different rings?Pistons?
07 Aug 2017 19:25
#768548
rings are in the right position.I do believe the ring grooves are off.As I take the the rings and slide the side of the rings in the groove it gets stuck in 2 parts of the groove.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Aug 2017 19:31
#768550
Not the other parts? All of them? I saw some old NOS ones on eBay.
  • zed1015
  • zed1015's Avatar
08 Aug 2017 07:58
#768569
Are you putting the rings outer face into the groove or fitting the ring on to the piston.
If it's the former then you need to fit the rings on the piston to see if the "problem" disappears.
The ring groove is not square towards the back and would cause the FACE of the ring to bind which would not be an issue when the rings are fitted correctly.
Have fitted hundreds of Wiseco pistons and never come across any ring fitting or machining faults.
  • clarkster
08 Aug 2017 11:56
#768579
2 of the ring stes went on perfect and the rings spin freely on the pistons.The other 2 the second ring will not spin in the 2nd groove.I bought the pistons used and they came with a new ring set.I have never used these pistons.I have only dropped a few piston and ring sets in and I have never had this problem.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Aug 2017 14:21
#768584
Pics of the bad ones?
  • clarkster
08 Aug 2017 20:25
#768615
i will post some tomorrow in the A.M.
This one has me stumped.I'm going to remove the rings from the other 2 pistons to mic out,compare and try on the other pistons
  • zed1015
  • zed1015's Avatar
09 Aug 2017 00:26 - 09 Aug 2017 00:37
#768619
Ah! didn't notice that the piston were used and the rings only stick in a couple of spots ?
Sounds like the ring lands have probably had a knock whilst in storage or during shipping .
You could use a needle file in the groove and carefully ease the tight spots until the ring seats with the same fit as the rest of the ring grooves circumference.
The high spots are most likely to be just on the outer face of the land and not in the depth of the groove.
Once done correctly you should be good to go.
Last edit: 09 Aug 2017 00:37 by zed1015.
