Front sprocket, left or right?!
- kzswe
14 Jul 2017 05:03
1982 z750 ltd twin.
Im trying to get the front sprocket of but unsure if its left or right thread..
Anyone know? Dont wanne break anything
- zed1015
Re: Front sprocket, left or right?!
14 Jul 2017 05:51
R/H thread.
Anti clockwise to loosen.
- kzswe
16 Jul 2017 07:25
Thanks! Been trying a while to get the damn thing off.
No luck with the nutrunner, thinking a long pipe to get stronger with the wrench.
16 Jul 2017 08:11
Assuming the swing arm is still on the bike if you have an old piece of chain and 2 bolts you can easily make a counter-sprocket holder as shown below. Just wrap the big loop around the sprocket and the small loop around the swingarm pivot and the sprocket will not rotate when you try to loosen or tighten the sprocket nut. Some folks have a friend stand on the brake pedal, but that could cause brake related problems, and some folks stick a pole between the wheel’s spokes which is very hard on the spokes. Using an old length of chain as shown below doesn’t put stress on anything at all and prevents the sprocket from moving when loosening or torquing down the sprocket nut. Ed
- kzswe
16 Jul 2017 11:07
Thanks for the tip, i locked it in a simular way with a Steel rod but sofar no luck.
The rod bent and the Bolt didnt give.
May have to grind it off, hope not!
16 Jul 2017 12:55
NO
- KZB2 650
16 Jul 2017 13:03
I took a hammer and chisel to shock mine once and it loosened it enough to get it by holding the brake on and using a breaker bar........ still have the spot on it where it marked it up..... which reminds me I once planned on replacing that because of that......
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- kzswe
17 Jul 2017 10:49
Im gonne keep this thread going because another problem occured, my local kawa dealer where i ordered new sprockets called today and said they cant deliver, that kawasaki dont make em no more.
I tried looking in my manual for a parts bo. but there my bike appear belt driven so no luck..
Do you guys know what i need and where to get it?
Not in the garage atm but i recall the rear sprocket got 40 teeth.
17 Jul 2017 11:22
I don't understand. When you look at your bike is it belt driven or chain driven? Ed
- old greek
17 Jul 2017 11:32
Google Partzilla, it says you have a 13 tooth front sprocket, their part # for it is.....K22-2734
The following user(s) said Thank You: kzswe
- kzswe
17 Jul 2017 11:53650ed wrote: I don't understand. When you look at your bike is it belt driven or chain driven? Ed
My bike is chain driven, and the sprockets are worn out.
I looked for parts number in a pdf for my bike i got from the dealer but the book says the bike has belt so no help there..
- old greek
17 Jul 2017 12:13
Heres one from Sprocket Specialist's Kawasaki KZ-750 H. L LTD Front Motorcycle Sprocket Yr(s) 80-83 SKU# 521
Kawasaki KZ-750 H. L LTD Front Motorcycle Sprocket Yr(s) 80-83 SKU# 521-1161
$26.99
Find what you need in one stop.
Need a Rear Sprocket? or Chain?
1
Add to cart
SKU: 521-1161 Categories: Front Sprockets, Kawasaki, Shop ALL Tags: Kawasaki, Kawasaki KZ 750 H. L LTD
$26.99
1
Add to cart
