Valve shim chart
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
The following user(s) said Thank You: Frank2shots
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Valve shim chart
08 Jul 2017 21:50
#766453
Specific to which engine(s)?
Thanx
1982 KZ1100-A2/1170 sleeper 😀
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
08 Jul 2017 21:56 - 08 Jul 2017 22:00
#766454
It is for any engine, as long as the specified clearance is 0.08 to 0.18 mm!:unsure:
Actually, Steve was likely posting to help a 550 owner, I think....
Last edit: 08 Jul 2017 22:00 by Kray-Z.
  • martin_csr
  • martin_csr's Avatar
09 Jul 2017 04:27
#766458
Here's how I record & save the numbers. I also keep a hard copy.
  • SWest
  • 10 22 2014
09 Jul 2017 06:42
#766463
I was asked a question last night before I went to bed so I put this up. I don't use metric so I thought it would help him. If someone has a better one, please put it up.
  • KZB2 650
  • KZB2 650's Avatar
09 Jul 2017 07:17
#766468
A 650s range is .003 to .007.......... shims are .002.......... if you have .002 clearance and want .004 you put in one size smaller if you want .006 put in a shim 2 sizes smaller....... If you have .008 you put in one size larger to get.006..... Have .007 and want .005 same or leave it and let wear close it up......why even mess with the chart.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • axel
  • axel's Avatar
29 Apr 2019 06:50
#802977
SWest wrote:
Can this chart be applied to a KZ550?
1981 KZ550 (carburetor tuned for pod filters)
  • loudhvx
  • loudhvx's Avatar
29 Apr 2019 08:56 - 29 Apr 2019 09:01
#802987
It's possible the chart for the 550 is the same, but probably best to use the 550 chart just in case.
I have a bunch of manuals you can download for the 550. You should get them all. The factory manual will have the shim chart. for a 550.
s3.amazonaws.com/gpzweb/Mnls/Mnls.html
Also, before doing anything with the valve cover, read the warning for details about the valve cover related to the timing chain.
This is the same link in my signature. It also has details on the way to measure valve lash clearance, and better images for valve timing.
s3.amazonaws.com/gpzweb/CamsKZZXZR550500...KZZXZR550500400.html
Also, if you follow the links in my signature, you will see a website specifically about your carburetors.
Last edit: 29 Apr 2019 09:01 by loudhvx.
  • Cfoux85
  • Cfoux85's Avatar
  • 1982 Kawasaki kz 750e
30 Nov 2022 10:54
#877350
I'm so confused on how to do this.  So I measure my clearances, find it on the left side of the chart. Then slide to whatever shim that's in it which would be at the top of the chart and that will tell me what size shim to put in?
  • Warren3200gt
  • Warren3200gt's Avatar
30 Nov 2022 11:12
#877352
Shims go up in increments of 5 thou. If yo need to increase the gap then you reduce the shim size. If you need to decrease the gap then you increase the shim size.
Eg if the gap is 8thou and you want to make it 18thou then reduce the shim size 2 sizes from what you have.
You don't need a chart. Just remember if you want a smaller gap increase the shim if you want a bigger gap decrease the shim.
  • Nessism
  • Nessism's Avatar
30 Nov 2022 11:20
#877353
Actually, shims go up in increment of .05mm, which is about .002"
The following user(s) said Thank You: Warren3200gt
  • Warren3200gt
30 Nov 2022 11:40
#877354
Type in haste, repent at leisure
