Oil scraper rings falling out of place and binding
- diego092409
05 Jul 2017 16:21
I have tried unsuccessfully two times to try to install the cylinder block on my kz110b2. Each time I have had a few of the bottom scraper rings fall out of place and bind up the entire cylinder block. All of the rings were sitting in the grooves before I began pushing the block down.
I talked with a coworker and he suggested scotch tape that would melt (it was a joke) but made me wonder if there is anything to temporarily hold these more delicate rings in place?
1982 KZ1100 B2 - 'Old Red'
kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
2015 BMW K1600GT
- Tyrell Corp
Re: Oil scraper rings falling out of place and binding
05 Jul 2017 16:27
Been there, done it, got the gouged bores...
There is a factory tool ring compressor, or just get a (skilled) assistant and do with you one each two at a time with wood blocks holding the block up. There is quite a decent lead-in champher on the liners...until you start boring out.
The following user(s) said Thank You: TwoCam
- zukdave
05 Jul 2017 18:10
I cut a band out of a 2 ltr soda bottle to rap the ring's then us a hose clamp to compress the ring's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- daveo
06 Jul 2017 06:06
This worked on the first-attempt for me...
www.kzrider.com/forum/21-tools/591927-ka...ssor?start=20#710233
1982 KZ1100-A2/1170 sleeper 😀
- KZB2 650
06 Jul 2017 10:55
Jay from APE told me to just push em in by hand when I asked him and that's what I did with very good luck ... thank God...... before hand though I read about this problem and Jay and Red line both told me to watch out for this so I was a nervous wreck till I had it bolted up and it turned smooth..... to be honest till I had a few hundred miles on it.
If I had it to do again I'd probably try the pop can and clamp trick or Daveo's..
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- diego092409
07 Jul 2017 04:08
First time I tried doing it by myself and it was fit to be tied. Then got the jugs off and tried again with the wife for an extra set of hands. I thought I had it together and fitted in there but it got tight. I knew they came off smoothly and that they should go back on smoothly. I didn't know if there was a sticky grease I could put on them to hold them in place or it was just 4 hands with chop sticks and being really patient.
2015 BMW K1600GT
2015 BMW K1600GT
- TwoCam
07 Jul 2017 04:44
I found it easest to block up the center cylinders, get them down, then do the outside ones...it's a real joy to do. a helper would make the job better.
