1979 KZ650 big bore
  • KZ650_Kent
  • KZ650_Kent's Avatar Topic Author
1979 KZ650 big bore
29 Jun 2017 09:34
#765660
I have a 1979 KZ650B that when I bought it the guy told me it has a 720cc big bore kit on it with a 750cc head. Is that possible? Does the 750 head fit the 650 block and cylinders?
  • Nessism
  • Nessism's Avatar
The following user(s) said Thank You: KZ650_Kent
  • KZ650_Kent
Re: 1979 KZ650 big bore
29 Jun 2017 11:28
#765665
do you know would I order a 650 or 750 header or are they the same?
  • Nessism
  • Nessism's Avatar
29 Jun 2017 12:49
#765669
The headers will be almost the same, although there are some variations in how they mount to the bike at the rear.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
29 Jun 2017 20:45
#765702
Welcome.
Post up some pictures when you can.
650/750 exhaust header spacing is the same, as are many 650/750 parts being swappable.
The 750 (738cc) engines are based on the 650 engine.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • martin_csr
  • martin_csr's Avatar
29 Jun 2017 21:56 - 30 Jun 2017 08:22
#765707
Some pics to show interchangeability of exhaust systems.
Here's Andy-the-Gringos 650 w ZR-7 exhaust. I think the ZR-7S is the same. (1999-2005 ZR750)
1981 KZ650-CSR w 1980 KZ750-E1 mufflers. direct fit. the 750E mufflers are 6" longer than the csr's.
both have a center stand recess in the left side muffler. the 70s mufflers don't have the recess.
Last edit: 30 Jun 2017 08:22 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
01 Jul 2017 05:39
#765819
This exhaust system may still be available.
www.kzrider.com/forum/23-for-sale/606327...em-chrome-vgc#765796
  • Tyrell Corp
  • Tyrell Corp's Avatar
01 Jul 2017 08:38
#765833
No eBay APP ID and/or Cert ID defined in Kunena configurationYoshimura kit, very rare now:
  • KZB2 650
  • KZB2 650's Avatar
01 Jul 2017 13:15
#765847
Hey Tyrell Wiseco made a 720 and 740 kit for years and finally dropped em for only the 700cc kit.....
if he has them would they be different ?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Tyrell Corp
01 Jul 2017 16:31
#765857
Don't know much about the 720 kit, other than I have a 12:1 cast piston race kit 3 ring 590 gpz550 kit.
They made different kits, from two ring and three ring in varying CR.
OP if these are anything like mine the ring wire circlip is 0.8mm...unobtainum for the 590 gpz kit , I had to make some teflon buttons. They actually went to all the effort for reducing reciprocating weight by a few milligrams.
Finally, the bore clearances are different on these. I have some tech info from Yoshimura Japan but was requested not to openly publish it online, pm me if you need.
