Clutch basket
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Clutch basket
26 Jun 2017 19:02
#765461
Started a clutch thread. I think I'll move the related items here.
  • VTEC
  • VTEC's Avatar
Re: Clutch basket
27 Jun 2017 17:56 - 27 Jun 2017 17:59
#765531
Hey Steve. Love that basket holder tool!
If you're gonna tear it down pull the generator cover first, and push the crank to the left to take up the endplay. Then look at the damping washer behind the flywheel. I'm assuming the KZ engine uses it also. If you see space between the damper and the case, that's a problem.
That damper is meant to pull the crank to the left and reduce endplay noise.
KZ1000-K2
ZRX1100
XR400R
Last edit: 27 Jun 2017 17:59 by VTEC.
  • SWest
  • 10 22 2014
Re: Clutch basket
27 Jun 2017 18:16
#765532
Been there done that. If it's too tight it will make the starter spin. The crank has no end play even without it. I tightened the motor mount bolts and that helped a little. I'm running out of things to check. I don't hear it at idle and you would think I would.
  • VTEC
  • VTEC's Avatar
Re: Clutch basket
27 Jun 2017 19:10 - 27 Jun 2017 19:23
#765538
What do you mean no endplay? In my book they don't give an endplay spec, but it should equal the thrust washer gap on the crank. About .015" - .020". You can't check endplay with the damper installed.
KZ1000-K2
ZRX1100
XR400R
Last edit: 27 Jun 2017 19:23 by VTEC.
  • SWest
  • 10 22 2014
Re: Clutch basket
27 Jun 2017 19:33
#765540
When I took the rotor off I pulled on the bolt to see if there was any play. None.
  • VTEC
  • VTEC's Avatar
Re: Clutch basket
27 Jun 2017 19:42
#765545
It may be the crank is tight and you need to pry or push harder to shift it back and forth. Every crank and cam has to have endplay or it wouldn't turn.
When are you hearing the noise?
My buddy that worked on the CHP bikes told me a story about a noise that drove him crazy. Thought it was the crank, and could only hear it riding, not in the shop. It turned out to be a messed up petcock rattling under certain vacuum.
KZ1000-K2
ZRX1100
XR400R
  • SWest
  • 10 22 2014
Re: Clutch basket
27 Jun 2017 20:32
#765549
I'll try to make a clip of it.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Clutch basket
27 Jun 2017 20:40
#765550
VTEC wrote: It may be the crank is tight and you need to pry or push harder to shift it back and forth. Every crank and cam has to have endplay or it wouldn't turn.
Lov'n the Pingle, whenever I've remembered to turn it off. :lol:
1982 KZ1100-A2/1170 sleeper 😀
