Oil cooler upgrade
- RetroRiceRocketRider
Oil cooler upgrade
09 Jul 2006 20:51
Since I'm planning on taking the ZN to the Vegas BikeFest this year, and knowing just how freakin' hot it's going to be tooling through the desert on the way there, I decided to install the GPz750 oil pan and cooler I had onto the ZN rather than onto my KZ650 during it's rebuild.
The oil pan is a direct fit, and even uses the same gasket and o-rings as the GPz750 and KZ650 do.
The lower mounting holes on the oil cooler lined up perfectly with the pre-tapped holes in the frame. Yet even with just those two bolts holding it, it's super securely mounted.
The only mod I had to make was cutting the center brace off of the horn bracket, and then slightly bending the now individual horn brackets to clear the oil cooler once mounted to their original bolt holes in the frame.
I think it turned out pretty nice.
And during the little two hour ride (city streets and freeway) Rose and I took earlier today, I didn't feel quite as much heat radiating from the engine as it did prior to installing the oil cooler.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- wireman
- CoreyClough
- GPz550 Addiction
Re: Oil cooler upgrade
09 Jul 2006 21:03
Cool shots, and I hope it cools the oil for you.
'85 GPz550(ZX550-A2)
- Sandy
- Fly High,Tony
09 Jul 2006 21:16
Looks good,Chris...right on,Bud...every little bit helps,hey.
1977 KZ1000 A-1
09 Jul 2006 21:47
Thanks for the compliments guys!
Between running into the house every 15~20 mins to cool MYSELF down (the thermometer in the garage maxes out at 100, and I'm guessing it was prolly at least 110 in there:pinch:), I'd say it took roughly about three hours total from draining the old oil to adding new oil once everything was bolted up.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- EddieBoy
- CoreyClough
- GPz550 Addiction
10 Jul 2006 06:33
Here's what the oil cooler mounting looks on my '85 GPz 550:
Looks the same as yours, but upside down mounting.
Post edited by: CoreyClough, at: 2006/07/10 09:34
