KZ1000 LTD - Trouble Starting
  • Rogan81
  • Rogan81's Avatar Topic Author
19 Jun 2017 09:09
#764774
Hi Gents -
I'm looking for a little help with my KZ1000 LTD. I recently changed the oil and may have overfilled a bit. The bike turns over and will occasionally run idle for a few seconds and then shut down. I hold the electric start button down for about 10 seconds and sometimes it starts but when I go to throttle it shuts down. Will overfilling the oil cause this problem? Any ideas?
Thank you in advance.
Re: KZ1000 LTD - Trouble Starting
19 Jun 2017 12:17
#764794
Rogan81 wrote: Hi Gents -
Would remove enough oil to achieve the correct level. Various pumps are available (or even a turkey baster with hose attached).
Good Fortune! :)
  • Rogan81
19 Jun 2017 12:23
#764796
Thanks Patton. I'll try to siphon some oil out this afternoon.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
19 Jun 2017 14:32
#764800
Would it be easier to drain a pint or so at a time from the oil filter drain? Drain, run, repeat as necessary?
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Rogan81
19 Jun 2017 15:20
#764803
So when I got home this afternoon I found gas all over my garage floor. I don't have a good feeling about this. Looks like gas is leaking out of gaskets etc. any help?
I attached pics but may not be the best quality.
  • Rogan81
19 Jun 2017 15:22
#764804
I disconnected and drained the tank. Not sure where to go from here.
19 Jun 2017 20:02 - 19 Jun 2017 20:03
#764822
Can't pinpoint source of leak from the pics. :unsure:
Leak may result from carb internal issue such as leaking fuel valve, or from an external issue such as a leaking fuel line fitting, etc.
Is the airbox filling with fuel?
Do the carbs have overflow hoses?
Is the petcock being left in PRI position? If leaking somewhere after the petcock (in OFF, ON or RES), the petcock isn't stopping fuel flow as it's supposed to, which allows fuel to continue flowing on to wherever it's escaping. In which case there's a petcock issue as well as the reported fuel leakage issue.
Good Fortune! :)
Last edit: 19 Jun 2017 20:03 by Patton.
  • VTEC
  • VTEC's Avatar
20 Jun 2017 16:45
#764909
No external leaks? It's needle and seat time.
KZ1000-K2
ZRX1100
XR400R
  • Rogan81
20 Jun 2017 17:03
#764910
Thank you for the input. I'm feeling a little helpless here. If I brought this to a shop do you have any insight on how much ch it would cost to get running?
  • zukdave
  • zukdave's Avatar
20 Jun 2017 17:56
#764912
Since it's a new to you bike I'd start with a petcock rebuild, carb rebuild and all new fuel hose,
drain the oil and add fresh oil
Might offer up some pizza and beer a little cash and see if someone close could come help
bet that'd be cheaper than a shop if you can find one that works on these old bikes.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • VTEC
  • VTEC's Avatar
20 Jun 2017 18:27
#764914
Rogan81 wrote: Thank you for the input. I'm feeling a little helpless here. If I brought this to a shop do you have any insight on how much ch it would cost to get running?
No way of knowing what they may charge. But what zukdave said is good advice if you're keeping the bike longterm.
KZ1000-K2
ZRX1100
XR400R
  • zukdave
  • zukdave's Avatar
20 Jun 2017 19:26
#764920
After going back and looking at the pic.'s first thing I'd do is new carb intake 's and factory clamps.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
