- Thank you received: 1
What do I do first? Snap and stalled.
- Rickman
:blink: sorry! but.. um... pics, please?It's toast! Pulled the head off tonight and the number 3 has a 1" hole in it and a valve welded to the top of it! This SUCKS!!!
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- trippivot
- Thank you received: 3
I'd like to see a picture of that piston of yoursIt's toast! Pulled the head off tonight and the number 3 has a 1" hole in it and a valve welded to the top of it! This SUCKS!!!
- rm3sweet
- rm3sweet
- rm3sweet
- rm3sweet
- rm3sweet
- rm3sweet
- steell
Another head shot. Can anyone tell from looking at the valves if I was running too lean or too rich?
A better question is, how many rpm were you turning when the valve let go? That motor did a lot of revolutions with the valve bouncing around in the combustion chamber :woohoo:
On automotive engines I have seen them bounce pieces back up into the intake and then into other cylinders, one valve taking out three or four cylinders
- wireman
- Visitor
- rm3sweet
I also noticed a sloppy primary drive chain which I'm suspecting was causing my rattling noise that would change when idle and pulling the clutch. I didn't know of course if the noise was normal or too loud because others have posted that these engines are a little noisey. Maybe just not as noisey as mine was.
As far as the coils. Can anyone suggest a good replacement?
Post edited by: rm3sweet, at: 2006/07/26 00:24
- Rickman
