What do I do first? Snap and stalled.
- steell
You need to have your cylinder bore checked before you do anything.
- rm3sweet
- steell
Besides I keep trying to think of something to replace it with and no other models really appeal to me. Seems strange considering the performance and ride short falls it has compared to other newer bikes.
You do realize you are on KZR where we all are certifiably insane in the same manner?
Cylinder could be fine or it could be toast, no way of knowing without checking. Why a Spectre top end specifically? I think the KZ/GPz/ZR7 interchange and I assume the Spectre does also, I just don't know of any advantage to using the Spectre. KZ750 uses a mechanical tach, 83-85 GPz750 head has no provision for the tach, I don't know about the others.
You think you're crazy? Sheesh, I ride a 750 twin, although someday maybe I'll finish my GPz750
Paul Smith (smithgpz) lives in Columbus and works on the old bikes.
- rm3sweet
The Spectra because the cams have .05mm more lift and a longer duration. More lift and open longer means more air and fuel. Add that to the smaller piston diameter gives a tighter combustion chamber. These details of course are what I have read. So I can't confirm this from first hand measurements or spec comparison.
- rm3sweet
- wireman
- Visitor
- EddieBoy
- Thank you received: 1
- brianrae33
1982 kz1000ltd
- rm3sweet
- rm3sweet
- steell
Is this from Rice Paddy?
- rm3sweet
