Mikuni Bs34 carb jet problem?
  • Lnovak7493
  • Lnovak7493's Avatar Topic Author
14 Jun 2017 15:47
#764381
Ok so im going through my carbs for my 1000 and after taking the bowls off i see this. The carbs dont have a pilot jet? Why and how does this work? Also is this correct?
Attachment not found
The carbs ARE vaccum diaphragm carbs
1981 kawasaki kz1000-k1 ltd
  • Lnovak7493
Re: Mikuni Bs34 carb jet problem?
14 Jun 2017 15:48
#764382
Im questioning the metal plug where a pilot jet would normally be
14 Jun 2017 18:50 - 14 Jun 2017 18:51
#764397
Would guess that there's a pilot jet screwed in underneath the plug; and thinking it's anybody's guess what's holding the plug in position over the pilot jet.
Good Fortune! :)
Last edit: 14 Jun 2017 18:51 by Patton.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Jun 2017 18:57
#764399
It looks to be held in by the float bowl.
  • Lnovak7493
14 Jun 2017 21:41
#764415
i thought that also at first but looking at it, its to far away from the bottom of the bowl. I believe its either press fitted or threads in. does anyone know for sure if that is supposed to be there in my exact carbs?
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
15 Jun 2017 03:39
#764420
It's held in by an o-ring. Put a drop of oil around it and pull it straight out with a set of pliers.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: GPz550D1, Patton
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
15 Jun 2017 05:12
#764425
ThatGPzGuy wrote: It's held in by an o-ring. Put a drop of oil around it and pull it straight out with a set of pliers.
Light weight oil, or little gasoline works too. For me, these plugs and o-rings were a pita royal. Even with extreme care gripping the plug (while removing) a couple would always get mangled and need to be replaced...the metal is very soft.
images.cmsnl.com/img/products/plugpilot-...20661087-01_e7ec.jpg
Have fun. :pinch:
1982 KZ1100-A2/1170 sleeper 😀
  • Lnovak7493
15 Jun 2017 08:00
#764439
Will removing them have any performance gain? Or will it negatively affect how it runs?
  • mopguy
  • mopguy's Avatar
15 Jun 2017 09:42
#764444
They need to be plugged as the pilot is fed by an opening in the main jet shaft.
The following user(s) said Thank You: GPz550D1, Lnovak7493
  • Lnovak7493
15 Jun 2017 19:22
#764477
Thank you for the direct answer man. I understand slide carbs but diaphragm carbs are a little different. I like the fact that the diaphragm carbs basically change the air to fuel ratio from the atmospheric pressure so you dont have to jet it for different elevations
  • Lnovak7493
16 Jun 2017 17:57
#764548
Ok so i tried starting it and it didnt start. It was flooded after i checked the plugs. What are the carb air screw settings supposed to be? I started it at 1 1/2 and it wasnt starting at all so i changed it to 2 1/4 which is what it was at before i cleaned and adjusted the floats. I also put new intake boots on it before i threw the carbs back on.
  • Lnovak7493
17 Jun 2017 08:21
#764574
Anybody know the air screw settings?
