WIX Oil Filter ?
  • kzdcw
  • Topic Author
  • 77' KZ1000A
12 Jun 2017 16:15 #764174 by kzdcw
WIX Oil Filter ? was created by kzdcw
Which Wix oil filter do I use in my 77' KZ1000A ? I think Part # 24942 ?
77' KZ1000A
  • SWest
  • 10 22 2014
12 Jun 2017 16:25 #764176 by SWest
Replied by SWest on topic WIX Oil Filter ?
Yep. they are a little larger than stock.
  • SWest
  • 10 22 2014
12 Jun 2017 16:33 #764178 by SWest
BTW with that part # it should come with the correct O rings. There's another one with the wrong ones.
  • kzdcw
  • Topic Author
  • 77' KZ1000A
12 Jun 2017 18:23 #764189 by kzdcw
Replied by kzdcw on topic WIX Oil Filter ?
Steve, But the big question is, will they fit ? I've been using Fram prior but the Auto Stores don't seem to carry them anymore and Wix seems to be a better filter.
77' KZ1000A
12 Jun 2017 18:55 #764191 by 650ed
Replied by 650ed on topic WIX Oil Filter ?
Be glad the Fram filters are not carried. They are without a doubt the worst motorcycle oil filter on the market. Ed
www.tobycreek.org/oil_filters/fram.shtml
motorcycleinfo.calsci.com/FilterStudy.html
  • SWest
  • 10 22 2014
12 Jun 2017 18:56 #764192 by SWest
13 Jun 2017 06:55 #764235 by martin_csr
Replied by martin_csr on topic WIX Oil Filter ?
Since the KZ oil filters are simpler, are those studies applicable?
13 Jun 2017 07:19 - 13 Jun 2017 07:32 #764242 by 650ed
I believe they are applicable. Considering that Fram uses the cheapest materials and assemblies in the non-KZ oil filters I have no reason to believe they would use higher quality materials in the KZ oil filters. The study at the link below compares motorcycle specific oil filters, and while the KZ filters do not have the metal shell and bypass valve they do share the filter media and some other aspects of the non-KZ filters. Notice in the second link below that at least some racing organizations have banned the use of Fram filters because of their failures.
The bottom line to me is that it makes sense to buy higher quality filters since they cost very little more than the Fram filters. Most folks change filters and oil at the very most only 2 or possibly 3 times per year, so we're not talking about a major expenditure. To me, for about $1 one can have a higher level of confidence in the oil filter which performs a very important role in protecting the engine, and to me that sounds like a bargain. Ed
RECALL
www.math.uwaterloo.ca/~rblander/FRAM_recall.html
Last edit: 13 Jun 2017 07:32 by 650ed.
16 Jun 2017 16:09 #764541 by VTEC
Replied by VTEC on topic WIX Oil Filter ?
OEM is always safest, and often worth the added expense. Some aftermarket oil filters are overly restrictive enough to turn on the oil light.
KZ1000-K2
ZRX1100
XR400R
  • SWest
  • 10 22 2014
16 Jun 2017 16:45 #764543 by SWest
The Wix is slightly larger with more surface area. No problems since 13.
16 Jun 2017 17:53 #764547 by zukdave
Replied by zukdave on topic WIX Oil Filter ?
OEM filters are $18.00 buck's at our local Kawasaki dealer.
NAPA auto parts stores have the Wix filter for about $5.00 bucks and they also stock filter's for a lot of other bike's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • SWest
  • 10 22 2014
16 Jun 2017 18:36 #764550 by SWest
