Shifting Gears
- daveo
Shifting Gears
11 Jun 2017 12:03
Most of my rides are in-town at lower speeds using first-second gears, so it makes sense there may be more wear between those two gears than the others.
Why does it require more effort to up-shift from first to second gear, than from second to third, etc.?
It always makes the shift to second gear, but from second to third (and above) it is simply a click, and it's there.
1982 KZ1100-A2/1170 sleeper 😀
Re: Shifting Gears
11 Jun 2017 14:14
You have to go past neutral.
- zed1015
Re: Shifting Gears
11 Jun 2017 15:00
First to second is a bit stiffer because you have to go past the spring loaded neutral detent.
- daveo
Re: Shifting Gears
11 Jun 2017 16:19
Feels like its hanging up some, when just past neutral. Could shift-fork wear cause such a thing?
Maybe it's just aging rider imagination. :whistle:
Re: Shifting Gears
11 Jun 2017 19:25 - 11 Jun 2017 19:28
No eBay APP ID and/or Cert ID defined in Kunena configurationI use a different lever. Still miss second once in a while. :dry:
Last edit: 11 Jun 2017 19:28 by SWest.
