1982 Kz750e revs high in neutral or with clutch in
  • Jon8329
  • Jon8329's Avatar Topic Author
11 Jun 2017 11:13
#764088
Carbs were jetted from 120 to 130. Works great accept when in neutral or clutch is pulled in revs up to about 4000 any help would be great
Re: 1982 Kz750e revs high in neutral or with clutch in
11 Jun 2017 11:23
#764090
Racing idle may result from air leaks through worn out carb holders.
Or might be due to an issue with the throttle cable or its adjustment.
Good Fortune! :)
The following user(s) said Thank You: GPz550D1, Jon8329
