Rubbing/Squeaking Sound After Starting
  • stratman
  • stratman's Avatar Topic Author
07 Jun 2017 13:11
#763842
When I start my bike, just as the engine is firing and I release the starter button I hear a brief rubbing/squeaking kind of sound which I assume has something to do with the starter clutch not behaving. Is that about right? If so, what do I have to do to fix it? If not, what the heck is it?
Thanks,
Barry
1981 KZ650 CSR
  • JR
  • JR's Avatar
Re: Rubbing/Squeaking Sound After Starting
07 Jun 2017 15:52 - 07 Jun 2017 15:53
#763851
For years I had a squeal as the engine fired and as I let off the start button and for years I thought it was starter clutch related. Didn`t happen all the time but happened more and more frequently as the bike aged.
So. Before tackling the starter clutch I decided to check out the starter motor. I took it out, opened it up. cleaned out carbon dust. cleaned the commutator ring with Deoxit D5, greased the planetary gears. (the manual explains what to do with all the starter motor innards). Brushes were in speck. Put it all back together and have not heard the squeal since and that was over a year ago.
Not saying that this is your problem but it might be worth checking out before you think about digging deeper.
My 80 750 and your 81 650 have very similar starter motor and starter clutch
Last edit: 07 Jun 2017 15:53 by JR.
The following user(s) said Thank You: stratman
  • KZB2 650
  • KZB2 650's Avatar
07 Jun 2017 16:05
#763853
I agree problems with the starter clutch makes more of a grinding rattling sound and slips while trying to start.....I'd consider leaving it alone unless it gets worse or try JR's fix.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • stratman
07 Jun 2017 17:44
#763864
Thanks, guys. It's only happening occasionally right now so I'll leave it alone and just keep an ear on it.
Barry
1981 KZ650 CSR
