78 KZ650 cam and carb swap
- Wildman1024
01 Jun 2017 21:45
I currently have a stock 650 engine with 22mm carbs. I am running a V&H 4-1 pipe with no baffle, just end cap and stock airbox with K&N filter. I am about to swap to some 750 cams and a set of 24mm carbs. Just curious about what I should run for jetting? Thanks
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
1973 Yamaha RD350
1983 Honda CB1100F
- KZB2 650
Re: 78 KZ650 cam and carb swap
02 Jun 2017 16:03
Check out the KZ650 historic race bike thread in the racing section to get you started..... maybe a search too. His jetting is probably closer to what you need than mine with maybe 110 or 112.5 mains. Think about a comp baffle for your pipe might run better with it.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
