Kz750 twin hard to kickstart
  • Backwoods_biker
  • Topic Author
29 May 2017 14:47 #763041 by Backwoods_biker
Kz750 twin hard to kickstart was created by Backwoods_biker
I bought an 82 kz750 csr last month I know it runs cause the guy got it to run before I bought it and he was having issues kick-starting it and I'm just stuck basically on why it's so difficult to kickstart like it takes my whole body weight just to even get it to budge. Any help with this would be much appreciated!
29 May 2017 15:03 #763044 by 650ed
Replied by 650ed on topic Kz750 twin hard to kickstart
If it was mine I would remove the spark plugs and then see if the engine was still difficult to cycle by using the kick starter and then by turning the crankshaft (under the ignition cover). If it is difficult by both methods there is probably an internal engine problem. If it turns over easily with a wrench on the crankshaft by with difficulty using the kick starter I would suspect a problem with the kick starter mechanism or possibly the tranny. Ed
The following user(s) said Thank You: Backwoods_biker
29 May 2017 15:05 #763046 by TexasKZ
Replied by TexasKZ on topic Kz750 twin hard to kickstart
That is why God invented electric starters.
  • Backwoods_biker
  • Topic Author
29 May 2017 16:07 #763052 by Backwoods_biker
Replied by Backwoods_biker on topic Kz750 twin hard to kickstart
Haha I personally hate starters and will only buy a bike if it has a Kickstarter so much simpler and I know the engine is easy to turn over with a wrench but I will try without the spark plugs and see what happens
  • Backwoods_biker
  • Topic Author
06 Jun 2017 18:03 #763753 by Backwoods_biker
Alright well I finally got around to it all but it's easy to turn by hand and I took the spark plugs out and it was so easy to kickstart I put them back in and hard has a rock again
06 Jun 2017 18:49 #763758 by 650ed
Assuming it runs ok and it kicks over easily with the spark plugs out but is hard to kick over with them in I believe you are just experiencing excellent compression. Keep in mind that on a 750 twin you are kicking against the compression of a 375cc piston each time, so there will be a fair amount of resistance. In fact, my old BSA 350 had a compression release gizmo that cracked open the exhaust valve when you kickstarted it. I removed that gizmo and found that little 350 needed a hefty kick to start. Ed
06 Jun 2017 20:23 #763776 by loudhvx
Replied by loudhvx on topic Kz750 twin hard to kickstart
Because it may have the biggest Kz pistons, it's probably the hardest KZ to kickstart. I've seen average sized people needing to put their whole body weight on Kz750 twin kickers to turn it over. I don't know if that's normal, but it is not uncommon.
07 Jun 2017 00:37 #763788 by Mk2Rookie
Replied by Mk2Rookie on topic Kz750 twin hard to kickstart
I am running kick only on my 750 twin and it does take a serious jump to kick it but starts on first or second kick. Keep ignition spot on and a good battery, then it is a easy bike to start compared to a Yamaha SR500.
  • Backwoods_biker
  • Topic Author
07 Jun 2017 08:44 #763822 by Backwoods_biker
Ya this is my first twin I have owned so it was just frustrating cause j have never had a bike so hard to kickstart but thanks for the help 650ed
07 Jun 2017 08:52 #763825 by loudhvx
For comparison, the inline four 650 practically starts if a leaf falls on the kicker.
  • Backwoods_biker
  • Topic Author
07 Jun 2017 09:26 #763827 by Backwoods_biker
Ya and that was the last Kawasaki I had was 79 kz650 and I was like I know for a fact the 650 was super easy to kick over
07 Jun 2017 10:39 #763831 by loudhvx
I don't know if you have problems with it kicking back, but I've often wondered if a small ignition delay, during kicking, might help against that. It's something I've had in the back of my mind for years.
