82 kz440 ltd backfires
- Jamieskz
20 May 2017 06:14
I just finished the putting new pipes on my 440 and on the first test ride it backfires every time I let off the throttle. It didn't do this with the megaphones. Any advise would be appreciated.
Attachment not found
- Nebr_Rex
Re: 82 kz440 ltd backfires
20 May 2017 07:03
A backfire on deceleration or a hanging idle usually indicates a lean condition.
You need to richen up your fuel mixture. Start with the idle mixture screws.
They are located under a plug on top on the engine side. Your best bet would be to
get a DynoJet jet kit for a '80/83 KZ750 LTD [KZ750H]. It has all the parts you will
need and good instructions to follow. You may wonder why this jet kit. There is no
performance parts currently available designed for the KZ400/440. Except for
having a cam reground. The KZ750 4 cylinder uses the same carb. The only
difference is the ventri size. The 440 has a 36mm throttle bore vs. the 750 34mm size.
The carb body castings and throttle butterfly valve are the only differences. They use
all the same parts including the slide and diaphragm. The DynoJet kit includes jets for
different stages of tuning/performance. It also has the hardware to remove the idle
mixture screw plug and the correct jet needles.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
20 May 2017 07:17
I assume the megaphones had baffles in them. Do the new pipes have baffles? Ed
- VTEC
20 May 2017 07:54650ed wrote: I assume the megaphones had baffles in them. Do the new pipes have baffles? Ed
With wide open short pipes you may not be able to eliminate decel popping.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
- Jamieskz
20 May 2017 11:39
The pipes are emgo universal turnouts. They have a small baffle
