Vacuum petcock to Manual conversion?
- NovaScottia
18 May 2017 18:48
I know this is probably something that gets asked regularly. I just can't find something specific.
I have a 78 KZ650 B (I think) and the stock petcock has me worried. It's dumped in the crank case once already. I know they make rebuild kits, I just had a crazy Idea. Would it be possible to block the PR part of the valve and turn it into the off then remove the vacuum function?
So:
Reserve = reserve
PR = Off
On - On with out a vacuum
Has anybody tried this?
So:
Reserve = reserve
PR = Off
I'm just here to learn about motorcycles. My name is a mixture of my nickname (Nova) and my actual name (Scott). I have done about 300 miles on BIcycle in NovaScotia and it is by far my favorite place to ride. I hope to revisit someday with something that has a motor.
- stratman
Re: Vacuum petcock to Manual conversion?
18 May 2017 21:12
I'm not quite sure what you mean but it would be pretty easy to install a manual petcock and just plug the vacuum port on your carbs.
Based on what I've read around here, there can be some pretty strong feelings on either side of the manual vs. vacuum petcock debate but I switched to manual recently on my '81 650 CSR.
-Barry
-Barry
1981 KZ650 CSR
19 May 2017 05:27 - 19 May 2017 05:50
I don't think it will work. The diaphragm plunger is what stops the flow of fuel, so you'd have to remove the diaphragm or the o-ring, but then there would be nothing to stop the fuel. The way PRI works is that it bypasses the diaphragm, engine running or stopped. With the petcock set to PRI with the engine running & assuming a full tank, there's still fuel flowing thru the main orifice in the petcock, but there's also fuel flowing thru the PRI orifice. Engine stopped, fuel only flows thru the PRI orifice as the diaphragm plunger blocks the main fuel orifice.
Installing a manual fuel valve is easy on the 81 650-CSR as it has a 34mm bolt hole spacing & there are plenty of options.
Earlier 650s are 44mm, so I think on those you might have to get a fuel valve & mounting plate. I've never seen a 44mm manual fuel valve.
Last edit: 19 May 2017 05:50 by martin_csr.
The following user(s) said Thank You: Zladdarn
- stratman
19 May 2017 07:38
Exactly right, Martin. The OP would need something along these lines:
martin_csr wrote: Installing a manual fuel valve is easy on the 81 650-CSR as it has a 34mm bolt hole spacing & there are plenty of options.
1981 KZ650 CSR
