exhaust system
- RonCan
exhaust system
17 May 2017 17:49
I'm looking for an exhaust system for my 1977 KZ1000A. Can someone tell me which year/model systems are compatible?
Re: exhaust system
18 May 2017 05:39
If you are looking for the correct stock system, you may be limited to the 1977-1980 A model. Partzilla has a pretty reliable crossover chart. If you want an aftermarket system, there are more possibilities. I believe all the 900s and 1000s through 1980 use the same header and mid pipe. Generally, the only difference is in the muffler hanger, and that can often be solved pretty easily.
There are new systems available as well.
The following user(s) said Thank You: RonCan
