1980 kawasaki 440 ltd
  • jwc
  • jwc's Avatar Topic Author
14 May 2017 12:27
#761931
have spark but backfiring through carbs, has points so where do i start ? any info appreciated.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 1980 kawasaki 440 ltd
14 May 2017 13:21
#761934
Hello jwc and welcome to KZR
First introduce your self and your bike, we loving pictures.
One picture say sometimes more than 1000 words .
Second get service manual for your bike.
www.kzrider.com/modules/ServiceManuals/kz440.pdf
This will help you to control and setup your ignition system.
Michael
14 May 2017 14:15
#761937
jwc wrote: have spark but backfiring through carbs, has points so where do i start ? any info appreciated.
The more information you provide the greater the chance that someone can help. So –
Does the engine run or does it just backfire when you try to start it?
If it does run, does it backfire throughout the rpm range or only at idle?
If it only backfires at idle, what rpm is the idle set at?
Does it backfire constantly or just occasionally?
Does it backfire more or less once the engine is up to operating temperature?
Does the bike have the stock air box and filter installed?
Have you tested the carb holders for leaks?
  • Nebr_Rex
  • Nebr_Rex's Avatar
14 May 2017 16:46
#761954
Scirocco wrote: Hello jwc and welcome to KZR
Michael
Yes, get yourself a manual and perform all the general maintenance for the engine and we will go from there.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
15 May 2017 19:17
#762001
Sometimes caused by insufficient (too tight) intake valve clearance.
Good Fortune! :) .
  • CPLSeraphim
  • CPLSeraphim's Avatar
19 May 2017 13:27
#762231
As everyone else stated, back firing has a cause of ranges, from timing (I think advanced timing, I am working on my timing on my 80 KZ440 at the moment as well.)
If you can, post a video on youtube so we can visualize everything that is going on. I have done that as well. Perhaps we can help each other a little bit. lol
I shall be telling this with a sigh
Somewhere ages and ages hence:
Two roads diverged in a wood, and I—
I took the one less traveled by,
And that has made all the difference.
~Robert Frost
