Identify my new engine rattle - 1981 KZ750 LTD
- Irish Yobbo
03 May 2017 16:04 - 03 May 2017 16:50
Started up my bike to go in to work today, and I made it about 50 metres down the road when the engine starting making a new rattling sound. The sound is coming from the left side of the engine. The noise is related to the engine speed and happens if it's in gear or not, or if it's in neutral or not. Since the clutch is on the opposite side I don't think it's that, unless, it's just a part that's come loose and rattling in the cover, but it sounds too loud for that. There's a video here:
Any ideas? It wasn't revving high or under load when it started, I was just rolling down the hill at about 40kph.
1981 KZ750 LTD
Last edit: 03 May 2017 16:50 by Irish Yobbo.
Re: Identify my new engine rattle - 1981 KZ750 LTD
03 May 2017 16:47
You seem to have forgotten the link.
Just guessing but I'd say starter clutch issue or the rotor may have come loose.
- Irish Yobbo
03 May 2017 16:50
I had used the 'video' link instead of the 'provider' link. Try that.
1981 KZ750 LTD
03 May 2017 17:35
Sounds like it's coming from the alternator cover. Use a long screw driver against your ear to pinpoint it.
- Irish Yobbo
03 May 2017 18:07
I have a mechanics stethoscope (which is really a small doctor's stethoscope I got as a child, which I've modified into a mechanics one) and I'll check that when I get back home. It just happened this morning, so I went back home, took the short video, then caught the bus in to work. I thought I'd just gather intelligence so I know what to look for before getting back.
I'm in Australia, if you're confused about the time
1981 KZ750 LTD
03 May 2017 18:15
Check the cam chain adjuster area as well.
- Irish Yobbo
03 May 2017 18:22
Can chain and adjuster is on my list to check, however it doesn't sound so much like chain noise. I think Nessism and SWest might be on the mark with a loose rotor, I could see that making this noise. But having never dug into this engine at all I don't even know where the rotor is - I presume the left crank cover? If so, that's where the sound appears to be coming from.
1981 KZ750 LTD
03 May 2017 18:29
No eBay APP ID and/or Cert ID defined in Kunena configurationThat's the alternator cover. Might as well order the rotor removal tool.
- Tyrell Corp
03 May 2017 18:35
Got my studio cans on, I hear some clutch basket and bottom end /primary chain clanking, increasing the idle and balancing carbs will minimise but not eliminate this. Was this a cold or hot motor?
Camchain rattle has a distinctive 'bunch of keys' tinkle to it and most pronounced at about 3k when the throttle is blipped. Not the sound I'm hearing.
Alternator rotor come loose / fastener(s) gone awol /or magnets delaminated? Use impact driver and threadlock here.
Try putting a rag over the exhaust temporarily and you can hear the motor a lot more clearly.
Any smoking / loss of power or charging issues?
- Irish Yobbo
03 May 2017 18:44
I've had a bit of primary chain noise since I've had it. This is a cold motor and yes, it disappears with revs (which is why I sped it up a little later in the vid). Carbs are synced, but I suspect one or two might run a little richer than others. But nothing I'm too worried about right now.
I didn't notice any smoking or loss of power, but I was literally 50 metres down the road when it happened (which is why it's cold), so I haven't ridden it enough to notice. I just rode it back and parked it.
I've read a few threads on rotors mentioning to use an impact driver and threadlock. Normally that sounds like a big no-no to me - is this because there is no easy way to lock the crank for tightening? Any chance I'll be stripping bolts if I do this?
1981 KZ750 LTD
03 May 2017 19:12
I have it in gear and use the rear brake when I'm tightening large bolts or nuts.
- Irish Yobbo
03 May 2017 19:31SWest wrote: I have it in gear and use the rear brake when I'm tightening large bolts or nuts.
I did the same for the crank nut when changing sprockets without issue - can't see any reason why I couldn't do this unless there is a component that can't handle it? I would have thought dropping the clutch would apply more torque than I could.
1981 KZ750 LTD
