Engine ID?
  • VTEC
  • VTEC's Avatar Topic Author
Engine ID?
28 Apr 2017 16:48
#760543
On an '82 KZ1000 is there anyway to tell if an engine belongs to a bike comparing the VIN and crankcase ID?
Also noticed that some cases have "KHI" before the ID number. What does that stand for?
KZ1000-K2
ZRX1100
XR400R
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
Re: Engine ID?
28 Apr 2017 18:02
#760548
My guess for KHI would be Kawasaki Heavy Industry
My understanding with the frame and motors is find the date the motor was made (I'm sure there is a chart someplace) If the frame build date and the motor build date are relatively the same time frame probably is about as close as your going to get. I don't believe Kawasaki was real good at making sure the dates matched. The frame would get what ever motor was next. could be a couple of months apart.
Blue 1975 Z1B
Red 2009 Concours 14
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Engine ID?
28 Apr 2017 18:21
#760551
KHI = Kawasaki Heavy Industry
1984 750 Turbo
  • VTEC
Re: Engine ID?
28 Apr 2017 18:29
#760552
I did a VIN search which showed manufacturer plant at AKASHI, Japan. That plant is still working today under the name Kawasaki Heavy Industry. Wonder if KHI means the engine was manufactured at that plant? The KHI is cast into the case, not stamped like the ID number.
KZ1000-K2
ZRX1100
XR400R
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Engine ID?
28 Apr 2017 19:01
#760555
If it says Kawasaki on the tin then it usually is, from WW2 Bombers, Channel tunnel boring machines, garden machinery or oil tanker ships.
KHI = kawaski Heavy industries.
You never get matching numbers on these, but they are usually within ten or a few hundred. More of a 'creep' on later models... ie i own 000022 Gpz550, but engine number was IIIRC 000028. Do this on a 10 000 serial number and it is sometimes double digits out.
If you have an engine number we can probably check it out for you.
  • VTEC
Re: Engine ID?
28 Apr 2017 19:23
#760556
Tyrell Corp wrote: If it says Kawasaki on the tin then it usually is, from WW2 Bombers, Channel tunnel boring machines, garden machinery or oil tanker ships.
What do you mean "Kawasaki on the tin"?
Here's the number. Thanks.
(KHI) KZT00JE029423
KZ1000-K2
ZRX1100
XR400R
