Severe Fuel Leak From Exhaust
- EdwardDaggerhands
www.dropbox.com/s/v31d8xhz47jut9c/VID_20170419_192829.mp4?dl=0
- Thank you received: 1656
The little holes in the mufflers are probably drain holes for the condensation to help minimize rust/corrosion of the exhaust system.
Is the stock airbox installed?
- Thank you received: 2234
Carefully cleaning them and replacing the old rubber bits usually takes care of it.
As Martin said, there is very likely fuel in the crankcase. Be careful when you drain it. A little spark could have unfortunate consequences.
- Thank you received: 2823
The drain holes in the exhaust pipes often plug up from rust flakes. It could well be though that you only have one leaking float valve, not two.
- VTEC
- Thank you received: 80
Does the vacuum line at the petcock go to the left or right carb? If it goes to the right, that's not the problem.
KZ1000-K2
ZRX1100
XR400R
- davido
- Thank you received: 292
I have bought a rebuild kit and plan to fit that after giving the petcock a good refresh. I think I better check the oil also,just to be safe. The fuel I drained from the tank looks clean and the petcock filter also looks clean.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Thank you received: 2829
- davido
My way of looking at it is to start at the beginning,which is the tank.If thats dirty,theres no point cleaning out the carbs or the petcock as theyll just get buggered up again. Is your tank clean Edward?
Then look at the petcock. Do you have a vacuum tap or the other sort? Is the tank filter clean? Im busy rebuilding mine. Scirocco dug up this link for me.Its very useful for rebuilding vacuum taps;
xjbikes.com/forums/threads/rebuilding-th...-valve-w-pics.25058/
(After that,Ill clean my leaky carb again and have a closer look at the float mechanism)
If you do get the tank and the tap clean,it might be worth putting an inline filter twixt tap and carbs.Just to be sure.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- EdwardDaggerhands
I will run the preliminary tests suggested by Martin and VTEC, then proceed with the steps David laid out (actual disassembly, cleaning, and replacement of tank, petcock, tank filter, carburetor, etc. components).
Does this sound like a reasonable approach to everyone? I appreciate all of the help! Getting these rookie hands dirty should be interesting!
- Z1Driver
- love the smell of triple smoke
- Thank you received: 55
If you are getting raw fuel out of your muffler drain hole, I would not attempt to start the bike until the leak is fixed. Getting raw fuel out of an exhaust pipe would mean fuel is also getting into the cylinder. Gas doesn't compress like air so there is a chance of bending a rod. Pull the plugs before turning the engine over to confirm no fuel in a cylinder.
Blue 1975 Z1B
Red 2009 Concours 14
- EdwardDaggerhands
Z1Driver wrote: The purpose of the drain holes in the muffler is to allow moisture to drain. Are you sure you are getting fuel and not water? Did you smell it to confirm?
Certain it's fuel. It wreaks of gasoline. So just be sure EVERYTHING is drained prior to starting work - is that what you're saying? Thanks for the feedback!
